Results 1 to 12 of 12
Thread: Rims on a 250SX.. what else fits?
    Pennsylvannia
    1,147
    So I'm looking into getting some rims for my SX. Douglas' or whatever I can find. What rims from quads would fit the SX/be the same size as the stock SX rims? I found a pair of 400EX Douglas rims on eBay and I was just wondering if they would fit. Front and/or back?
    springville, PA
    6,185
    Remember there is a brake drum behind the right wheel so I wouldn't go smaller. What size are the rims?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Pennsylvannia
    1,147
    Hmm crap. I believe they are 9's. The tires are 20-10-9.. so doesn't that mean the rims are 9's?
    Are stock SX rims 11?
    springville, PA
    6,185
    sx rims are 8". 22x11x8. 22"=diameter, 11"= width, 8"= rim size. Make sure it has the same bolt pattern as the SX too otherwise it wont bolt up.
    Nate
    R.I.P HRR
    Pennsylvannia
    1,147
    Whats the SX's bolt pattern? These ones have a 4 bolt pattern as well, but how do I know if they will be right width apart?
    Eastern Long Island
    1,688
    Both the 400EX and the 250SX are a 4 on 110 mm bolt pattern. The 9" ITP rims that were on my 350X(also 4 on 110) fit my SX perfectly.
    Lots O Trikes!!!!!
    Dec 2002
    Kansas
    2,387
    8" aluminum wheels will not fit over the brake drum.
    I had the RIGHT to remain silent, I didn't have the ability!
    Pennsylvannia
    1,147
    Why? Will 9's?
    Nov 2004
    Waterloo IL
    2,701
    My dad has a 250SX with bent up rear rims, we tried to put stock 85 ATC250R rims on back and they wouldn't clear the drum. ???
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    I don;t see any reason a 9 inch from a 400 ex won't work. I run 10x10 douglas wheels on my big red and the stock big red rims are 9 inch. As far as I know the rear brake drum is the same. Almost all the hondas use a 4x110 bolt pattern except the smaller ones and rally clasic ones.
    Pay attention to back spacing the last thing the 250sx needs is to be thinner.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Rittman, Ohio
    6,276
    They have rims designated "large bell" to accomodate those machines with drum brakes housed inside the rims. Some regular 9" will not fit. Others will.
    Pennsylvannia
    1,147
    Crap. Well badpig is selling two sets of rims and paddles. One is on Douglas blue rims, and the other on steel rims. Would either work?? I was very interested in the Douglas'.. but it'd suck if they didnt work.
