Results 1 to 6 of 6
Thread: rigged a light on atc 70...
    Ddw350's Avatar
    Ddw350 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    actually dont look bad,its a smaller rectangle utility light,not very bright though,but is alot better than nothing.i tapped into the dark green wire which evidently is used for lighting on newer atc 70s.mine is an 82.put a switch beside the air cleaner[drilled a 1/2 hole in the double wall frame part]..i might try a different light to get a little more output,but i know this thing doesnt put out alot of current for lights...i'll get a pic soon
    Pennsylvannia
    1,147
    Could you possibly run a battery on it? Hook the battery to the stator to charge it so it doesn't go dead fast, and hook the battery to the headlight and use it just for the lighting. Just figured I would give you an idea. I don't know how hard it would be to do though..
    '85 250SX - My first ever trike and my pride and joy
    **Check Out The Whole SX Project Here!!**
    '85 350X - 10:1 Piston, performance cam, '86 engline/carb
    '85 Powervalved Tri-Z - Fully modded - Soon to have a Corey Sprock 310 kit
    '85 250R - Began the modification process. This bike is going to scream! -295cc kit, Ported, Drag intake, 40mil Keihin, VForce reeds, shaved head, PT High Rev pipe, Fat Boy 2 Silencer, +4 Durablue axle, +2 swinger-
    Ddw350's Avatar
    i thought of that...it havta be a pretty small battery,i think it would work.the light is kinda bright when its dark,but its not really a concentrated beam,it kinda puts out like a wide field of light,making it not seem very bright.i might try like a 10$pepboy light..
    Pennsylvannia
    1,147
    Well it wouldn't need to be TOO small. Just put a regulator and such on it. I'm sure the electricians will step in in a little bit to help you.. lol
    Ddw350's Avatar
    i never was good at electronics!!
    SoCal
    9
    Dr Atv has 6v light set ups fairly cheap
    http://dratv.com/athekitinwo.html
