Results 1 to 9 of 9
Thread: 1985 125M spark help.
    CT
    674
    Okay I just got a 125M and it has no spark. What can I do to get spark? Are there points in these engines? Is there any other common problems about this issue i should look for? The electric start works and the neutral light works and the headlight turns on so I dont think the whole elctrical is screwed up. But anyhting i should check and or do to get spark?
    86 Honda 200sx (needs alot of work)
    82 XR200R (runs great, now the daily rider)
    91 acura legend junker, selling to get a truck
    2001 GSXR600 Part out, PM for info or for parts.
    Pa.'s Highest City
    8,058
    Replace the excitor coil (I think that's what it's called) inside your stator.
    http://www.crosstec.com/wc.dll?ctwp~...ch~1001~1002~1
    Aug 2004
    Ab Canada
    4,368
    Are you sure your plug is good....?
    1985 Tri-Z-
    CT
    674
    its a brand new plug judst bought it today BR8ES
    Howdy's Avatar
    Celina, Ohio
    10,079
    Here is a posting with some electrical testing info. It may just help you locate the problem.
    http://www.3wheelerworldforums.com/p...getip&p=198405
    Here is another with a check list.
    http://www.3wheelerworldforums.com/p...=getip&p=59902
    Howdy
    Pa.'s Highest City
    8,058
    Quote Originally Posted by Howdy
    Howdy
    For some reason I'm not privliged enough to view those links! What's up with that?
    CT
    674
    I cant veiw the pages either...New2ATC, you do not have permission to access this page. This could be due to one of several reasons:
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by chrisr200x
    Well just slap me silly! I copied the link to the IP address instead of the link to the page / post. argg
    Anyhow here is the correct links:
    http://www.3wheelerworldforums.com/s...02&postcount=8
    http://www.3wheelerworldforums.com/s...05&postcount=6
    Sorry about that!!
    Howdy
    CT
    674
    thanks for the help Howdy, but i got it running. It turns out that the spark plug boot was bad. I put the boot off my moped on it and pulled it and it fired right up 1st pull. Runs good smokes a little on startup, but overall good. Now all I need is the carb. rebuild kit for it and i should be golden. It only runs for a few minutes untill it dies and then i wait a little bit and it runs again for a few minutes.
