Results 1 to 7 of 7
Thread: Piston removal, 2 stroke help pls !!!
    Jul 2004
    Mud hill. close to water !
    3,658
    I have my friends yamaha DT 125 in my garage right now. and we took the carb, head, cylinder off... and need to remove the piston from the crank.. not as easy as it should be.
    Gotta love clymer " Remove pin by pushint it with a wooden dowel " yeah...
    The top ring has a 1 inch piece missing from it.. and one of the clips are missing.. so i removed the existing clip on the left side.. and tried to get that pin out with a proper size socket.. tried to tap it but i don't want to stress the crank.
    The entire bottom end was floating in gas, as the carb was leaking into it.
    I need help with removing this pin.. any tips ?
    Currently :
    Houston,Texas
    1,044
    Have someone hold the rod and piston, and take the socket, and tap it with a . Don't go crazy, but it shouldn't hurt the crank.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Jul 2004
    3,658
    Quote Originally Posted by bigredhead
    Been there.. done that.
    next option ?
    Currently :
    Aug 2004
    Ab Canada
    4,368
    Piston pin pulller, i belive princess auto carries them....dont quote me on that tho...search the net!
    1985 Tri-Z-
    Jul 2004
    3,658
    Princess auto.. heck. never thought of that.. i bet they have it.
    Googling for the past hour.. i might try threaded rod and washers with a few nuts as a home made puller...
    but princessauto is an option for sure.
    thanks.
    Currently :
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    Big C-clamp, 1 big socket, and 1 small socket, and 4 hands. The smaller socket to push the pin, and the larger for the pin to go into so it wont bottom out on the C-clamp. Worked for me many of times.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Jul 2004
    3,658
    Quote Originally Posted by oddball3
    Funny you mention.. i had the C-clamp on it with a small deep socket to push the pin.. and was trying to line it all up by myself.. when my friend and his buddy came along..
    Buddy has done this 100's of times before.. he grabbed the and the socket and got it out in 2 minutes !!
    I was not being agressive enough.
    Thanks guys !
    Currently :
