Results 1 to 15 of 27
Thread: ATC 110 losing power
    Sep 2005
    Houston,TX
    9
    Thumbs down ATC 110 losing power
    I have a Honda 110 ATC that seems to bog down after about 10-15 minutes of riding. It runs fine then all of a sudden you hit the throttle and it wants to die out. Once it sits for a few minutes it will fire right back up and can be ridden for about 5 minutes before the same thing happens. It has good compression and spark. Cleaned the fuel tank, carb, put new filters and gas lines on it but didnt help. I did notice that the gas is not flowing freely through the filters. (bought at O'riley auto parts). Have to squeeze the gas lines for the filters to fill up(maybe just running out of gas??) Is there a certain type of filter needed. I also heard it could be the gas cap not venting right? Just trying to figure out what direction to go in to try and fix it - fuel or electrical. Any help is greatly appreciated.
    Thanks
    Richland WA
    808
    Ought to get a strong stream out of the hose, Id look at fuel system. The filter should flow just hanging there. Compare how much it flows in 10 seconds without the filter, then with.
    Sep 2005
    Massachusetts
    1,272
    I had a problem like that with one of my old TS125's. Ended up my petcock had a mud wasp nest in it
    Sep 2005
    Houston,TX
    9
    Guess I'll see how the gas is flowing through first and then check the petcock.
    Thanks for the replies....
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    Try lettin it flow with the gas cap on and then with it off, you might have a venting problem with the cap. I see it alot with lawnmowers. Will run great for a while till you get vacume in the tank, let it sit and then it will start and run again for a little while.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Sep 2005
    Houston,TX
    9
    So if it is a venting problem, what do i do? Buy a new cap...
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    Yes, buy a new cap. Iv seen the caps with alot of rust in them also that they wouldnt vent right.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    Sep 2005
    Houston,TX
    9
    Thanks for the help.
    I will try to get to it tonight, the weekend for sure.
    Thanks for giving me a place to start...hope it fixes it
    Apr 2003
    Central New York
    1,860
    hm
    I had a Quadsport 230 that did that after I didnt put a part back on at the point where the muffler goes into the motor. I forget what it was but I remember thinking it unimportant.
    It would run till she got hot, then it would start to sputter and stall. It would take about 15-20 minutes befor she would restart. It took a week of trying all the above stuff before I decided to put that small part back on it.
    It ran great till I sold her a few years later.
    Just a thought in case you messed with the exhaust and its missing a gasket or whatever.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Sep 2005
    Houston,TX
    9
    Cant say that I have messed with the exhaust but i will take a look anyway. The more help the better....
    Sep 2005
    Houston,TX
    9
    Can anything electrical cause this problem? CDI, coil, stator....just in case everything else checks out ok. Like if a wire is cracked or frayed it will heat up and expand causing it to lose connection and once it cools down again it will be fine...and so on.
    Brandon, Manitoba
    2,209
    Is the inline filter made for engines with a fuel pump? I know that may restrict the flow of gas, but you were saying you had the sqeeze the lines to make it fill the filter so the petcock is probaly clogged of rust or something. try that first, if it still doesnt work, it could be the cap not venting, take that off and run it for a bit with something over the hole just so the gas wont come out.
    Sep 2005
    Houston,TX
    9
    Not sure, just went to the part store and picked out two small fuel filters. Guess thats not the best way to do it. I cleaned the tank (pretty dirty) but didn't mess with the petcock. I'll start there.
    Thanks again guys for the help.
    Brandon, Manitoba
    2,209
    Yea, take the petcock off and blow compressed air through the opposite way the gas flows. Switch it to reserve and blow through again. A bunch of crap should come out. You say your tank was dirty, I'll bet it's your petcock.
    Sep 2005
    Houston,TX
    9
    Does the petcock have any type of screen in it? Should I replace it or just clean it real good. After cleaning the petcock itself.
