Results 1 to 15 of 22
Thread: ford bronco II any good?
    I'm thinking about trading my t-bird sc for a 87 ford bronco II. I want something to haul the trikes around with. Its got 120,000 miles, and I know its been beat on, the last 5k. Anyone know how many miles they're good for? I'm not a big fan of fords, every one I've owned needed a tranny or motor. Let me know if they're any good. Thanks
    Work smarter, not harder
    Rides:
    '85 350x
    '80 cb650c
    Ashland City, TN
    2,576
    Bronco Jr's suck. If you have either a V-6 or V-8 in your T-Bird, I would reccomend putting a trailer hitch on it for hauling over the Bronco Jr.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Minnesota
    790
    i kinda have to agree with SSJ3Goku... Fullsize aren't so bad though Personally i'd much rather take an S-10 Blazer.
    cedar falls, IA
    546
    I have owned two bronco IIs and I would not have wanted to pull anything with either one. The engines come off the assemly line with less than 100 hps (Im pretty sure) . They will run for ever though. The only thing that I ever had to replace on them was the coil ...$12 part. Get something with some balls if you want to pull anything.---Joe 8)
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
    i have a suggestion for you...buy the dodge power ram from iluvmyxandr that thing will haul anything and everything you want it too no problem, it in the classifieds... thats my girlfriends stepdad. :-D :-D
    Jonathan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Re: ford bronco II any good?
    Quote Originally Posted by 350xing
    No
    I like motorbikes!
    Dec 2002
    Spruce Pine, Alabama
    1,263
    I am a diehard Ford man to the core( I've owned twenty-something Fords). I've owned 3 Bronco II's. Two '85's and an '86...all 4x4. The motor will last, but beware of the weak 7.5" rear end in the earlier models and stay FAR away from the ones with the A4LD automatic tranny unless you have a money tree, or unless you never intend to drive it. The A4LD is crap!
    '84 ATC70.....my 8-y.o. son's ride
    I guess its a no go. I'll have to look for something else. Really wanted a pickup anyway.
    Thanks guys
    Rides:
    '85 350x
    '80 cb650c
    Dec 2002
    1,263
    Hey tecatecrazy,
    I've pulled a 1-horse trailer with a 1000-pound horse with a Geo tracker 4x4 with a dead miss that only had 80-something hp when in top condition! Don't underestimate the worth of a low set of gears.
    cedar falls, IA
    546
    yeah that great dixie but I would bet it wasnt something that you would want to regularly...am I right. I wasnt saying that the bronco was incapalbe, more simply that it wasnt designed for towing.---Joe 8) oh yeah and the torque sucked too
    84 tecate (my baby)
    Dec 2002
    1,263
    You're right about me not wanting to tow regularly with that set-up. Both the Bronco II(which is over 100hp.) and the Tracker are fairly weak for towing purposes, but towing 1-2 three wheelers isn't really that big of a load. I swore I would never own another Bronco II after all the problems with the last one.
    My F-150 4x4(302 w/5-speed) is another story however. :-D
    theeechozen1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2002
    368
    ok brothaman--here's the scoop, I had a bronco 2, 86 with the 2.9 v6 and 223,000 original miles, It was one of the most capable 4x4's that I have ever wheeled in stock trim. With street tires that little truck would go everywhere, I know alot has to do with the driver but I have outclimbed a few lifted YJ's, I dont know about towing with them but I did tow a ford ranger on the freeway for 22 miles and had no problems. I paid 550.00 for this truck and got thousands of dollars worth of fun from it, for a good reliable beater 4x4 you can't lose--good luck
    1985 YAMI TRI-Z RZ350 POWERED
    1986 250R STOCK WITH FMF & K&N
    1986 TRX70 mini golf cart
    TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
    Dec 2002
    1,263
    All of my Bronco II's were mountain goats when it came to climbing, I'll give the truck that credit. Just not much of a tow vehicle, though.
    I built one '85 up a little. I put a 3" body lift, a 6" Skyjacker suspension lift, and a set of 33x12.50 Kumho(sp?) mud tires on 15x12 wheels. That som-b would go fairly well!
    Detroit, MI
    837
    We owned our Bronco 2 for 10 years and were the original owners, It used some oil, but ran great, and still ran strong. We sold it because my parents began to become fed up with its poor power. The thing had NO BALLS whatsoever, none, even with 5,000 miles on it. Ours was a stick and 4X4 also. Went through some trailprotrailprotrailprotrailpro too, suprisingly with as weak of a motor as it has. I would not suggest pulling anything with it though. If you have a small flat bed trailer with a couple trikes on it you should be fine, but then again a thunderbird SC can do that too. If your SC hasn't blown a head gasket yet, it will very soon, GUARNTEED. The 3.8's are renown for head gasket problems, I've never seen one with out a blown head gasket.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Nov 2002
    368
    I'm not sure about the SC'S power output, but on my grand prix gtp its got a 3.8 with a m-90 blower on it (similar to the t-birds) and with 280lbs of torque I know that thing would tow a good load with the right suspension --- put some koni's on the back and use it, why the hell not??
