200x carb on 200s
like iv said be for my 200s has a swing arm and atotally differint frame i know that it would clear in thier but would it work and whats the perfor mance difference
The 200s's and 200x's top ends are pretty much identical therefore the carb is identical so there would be no diffrence in power. Unless you've done drastic performance mods to your motor all a bigger carb would do is give you trouble. If your motor is stock just use the stock carb. If its not stock then just rejet.
but the the 200x carb has more comression
//ArrowChat Integreation Code
