Results 1 to 13 of 13
Thread: Need Quick answer!
    Aug 2002
    West Central Idaho Mountains
    13
    Need Quick answer!
    Hi, I just traded an old 22 rifle for a 79 ATC 110 Honda and I just finished cleaning the crud out of the carb. I decided to change the oil and dropped the oil plug out and saw another plug on the left side and thought it was like my Kawi Vulcan and was another drain plug with a screen and so after removing it and seeing the heavy and light spring drop into my hand and the "whatever it is" above not want to come out, I realized it probably wasn't what I thought it was and so now I figure it is some sort of adjustment screw for cam or clutch or something. Please tell me what this is and what I need to do! my wife actually wants to go riding today and I need to get it going ASAP or it will be weeks before we can do this again.
    Thanks very much.
    Baltimore, MD
    6,088
    I belileve that is the spring for the automatic cam chain adjustment.
    Aug 2002
    13
    So I tighten it all the way and put the plug back in?
    I have no reference books, manuals etc. for this trike.
    Dec 2003
    SE PA
    683
    Yah just tighten it back in. The spring tension against the chain adjuster makes it automatically adjust.
    [FONT="Palatino Linotype"]~My Rides (to name a few) ~
    1986 ATC250R, 1985 ATC350X
    1985 ATC250R Missile (90% done)
    1983 ATC185S
    1999 TRX416EX
    2003 Honda CBR600RR
    1990 Yamaha Zuma
    1985 XR80 w/100 motor
    1967 Honda CB77, '65 CL77
    1962 Puch 250 SGS
    1984 XR350R (owned since I was a kid)
    1972 Suzuki T350 Rebel, '73 T500 Titan
    1964 BSA A65 (needs restored)
    1968 BMW R60/2 mint original bike
    1976 Kawasaki KH500 triple
    Anybody have parts to trade for the above models?
    Baltimore, MD
    6,088
    No, don't do it like that, tell me what pieces you have in your hand, I have a manual right here and I can tell you in what order to put it back together and how to set it.
    Aug 2002
    13
    OK There is a piece of hardware that I couldn't get out. Then a light spring, then a shorter but heavier spring, then a threaded unit with a screwdriver slot for adjusting it I assume. Last is a plug/cap to cover it all. The adjuster wasn't very far in when I pulled the cap. It is a long way in if I bottom it out.
    Baltimore, MD
    6,088
    The longer light spring goes in first, then the heavy spring, then the piece with the screwdriver slot don't put it in real tight then you will have to set the spring tension with the bike running, get it all in and I will tell you how to set it while running
    Aug 2002
    13
    OK Will do. Maybe I should call you to do this easier. Can you PM me with your # if you think that is a good idea ?
    Baltimore, MD
    6,088
    moparman, on the side where the springs go back into you should see a nut with a piece that has another screwdriver slot in it, loosen the nut up and turn out the slotted piece about half a turn with the trike running, if the cam chain still sounds noisey after doing this, then you will have to turn in the screwdriver slotted piece holding the springs in and hopefull this will quiet the cam chain down. Once either one of these are done, turn the slotted piece on the side back in half a turn and lock it down with the nut, make it snug, don't try and kill it, then you can put the cap piece back on the bottom with it's sealing washer and you should be good to go.
    Baltimore, MD
    6,088
    If my directions aren't making sense, I can pm you my number, i'll just have to get off the computer for you to get in touch with me, let me know which would be easier, I'm in baltimore, MD-long distance.
    Baltimore, MD
    6,088
    PM sent, but you have to let me know your calling so I can log off and free up my telephone line, not very high tech.
    Aug 2002
    13
    THANKYOU THANKYOU THANKYOU!!!!!!!
    Got it running, got it working, and had a GREAT time with my Sweetie!
    She wants to do it again even
    Here's to everyone that helps out so often on this forum!
    Baltimore, MD
    6,088
    Happy I could help, everyone on here is very helpful and helped me a few times. After talking to you on the phone I went out riding on my 82 185s, hope you 2 had even more fun than I did.
