Results 1 to 12 of 12
Thread: Cylinder Replating?
    Houston,Texas
    1,044
    Cylinder Replating?
    How much does cylinder replating go for? Do you have to replate every time you bore the cylinder?
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    daputz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    a proud cheese head
    207
    I've personally never had a cyl replated, but I have heard great things about these guy's Max Power. I have talked with them, and they are very straight forward and more then happy to answer questions.
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    Millenium Technology does our snowmobile cylinders. Send them the new piston with your cylinder and they set the clearances.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Houston,Texas
    1,044
    Ok, I just heard that it can be upwards of $200 to have a cylinder replated, not cool. I am thinking about having the cylinder re-sleeved with a steel liner instead. Reason being, I have a standard bore piston kit sitting here, and I wouldn't have to bore my cylinder and re-plate it.And, I can bore it later and not worry about replating. Any opinions? Can someone point me in the right direction?
    Aug 2004
    Ab Canada
    4,368
    Why are you replating it? is the bore scared or plating wrecked? it takes ALOT of time to wear out a plated top end and they do not have to be bored out eveyrtime you rebuild it....
    1985 Tri-Z-
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    If you currently have a plated cylinder, and have it resleeved with an iron cylinder you will have to get new rings anyway.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    Mar 2005
    ma
    988
    if you get it sleeved with a new steel liner it will cost you about the same amount. $80 to $100 for a sleeve and then other $100 to have the sleeve installed. and supposably a plated cylinder is a better cylinder. dissapates heat faster through the cylinder.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Nov 2004
    Waterloo IL
    2,701
    What kind of plating are you refering to? Nikasil?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Las Vegas, NV.
    2,538
    Quote Originally Posted by sblt500r
    There's also less friction & the plated surface is harder than a standard steel sleeve. All this comes at a cost though.
    Quote Originally Posted by Blown 331
    Yes, that's correct.
    Houston,Texas
    1,044
    I was qouted $88 for a L.A. sleeve. Ct racing will sleeve my cylinder for $150.I think that includes the sleeve, I am not sure. I probably should have it re-plated, but every time the top-end goes, I will have to pay $200 if the plating was damaged. I will spend more money that way. This way, I will also have a fresh cylinder, and I can have it bored without re-plating it.
    Las Vegas, NV.
    2,538
    Quote Originally Posted by hondatrikesrule22
    You're looking at the situation all wrong. It is true that it'll cost more to repair "if" the top-end goes, so don't let it go. My cylinder is Nikasil plated, so I use that as a scare tactic to make sure it's jetted properly, because I don't want to buy a whole new cylinder or have to go through the replating process. And if you're putting so many hours on the same old piston that the piston finally lets go, you need to change it a little more frequently.
    Jul 2003
    indiana
    892
    You can actually just hone your cylinder that you have now even though it is plated and it wont really hurt anything. I have done that before. But the plated cylinder does have its advantages like people above have stated. If you run a clean and oiled air filter, and tear your top end off every so many hrs.(like whatever is recomended in your service manual) and your bore is in good shape and the piston isn't all scuffed up, which it shouldn't be if you do the recomemded inspection at the correct intervals, If the bore and piston is fine just put a new set of rings on and you are good to go. I had the cylinder replated on my old yz 125 and it lasted until I sold it and that was a good 3 yrs. All i did to it was ter the top end off every 25-30 hrs or so and check everything out and install new rings on the piston. Oh and had a squeaky clean air filter in it all the time.
