How much does cylinder replating go for? Do you have to replate every time you bore the cylinder?
"I am going out of this world.....the same way I came in...screaming and covered in blood."
I've personally never had a cyl replated, but I have heard great things about these guy's Max Power. I have talked with them, and they are very straight forward and more then happy to answer questions.
Millenium Technology does our snowmobile cylinders. Send them the new piston with your cylinder and they set the clearances.
IN MY GARAGE:
1984 250r
1986 350x
1986 200x(wifes)
1985 200x fixer upper
1979 110 PARTING OUT
1984 70
http://www.hardcoresledder.com/forum...post&id=155447
'97 ZRT 600 drag sled
'97 ZRT 600 trail sled
'98 ZR 440 sno-pro(wifes)
http://www.hardcoresledder.com/forum...=post&id=79401
Ok, I just heard that it can be upwards of $200 to have a cylinder replated, not cool.I am thinking about having the cylinder re-sleeved with a steel liner instead. Reason being, I have a standard bore piston kit sitting here, and I wouldn't have to bore my cylinder and re-plate it.And, I can bore it later and not worry about replating. Any opinions? Can someone point me in the right direction?
Why are you replating it? is the bore scared or plating wrecked? it takes ALOT of time to wear out a plated top end and they do not have to be bored out eveyrtime you rebuild it....
1985 Tri-Z-
Originally Posted by mywifeknowseverything
If you currently have a plated cylinder, and have it resleeved with an iron cylinder you will have to get new rings anyway.
IN MY GARAGE:
1984 250r
1986 350x
1986 200x(wifes)
1984 70
if you get it sleeved with a new steel liner it will cost you about the same amount. $80 to $100 for a sleeve and then other $100 to have the sleeve installed. and supposably a plated cylinder is a better cylinder. dissapates heat faster through the cylinder.
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
What kind of plating are you refering to? Nikasil?
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
There's also less friction & the plated surface is harder than a standard steel sleeve. All this comes at a cost though.Originally Posted by sblt500r
Yes, that's correct.Originally Posted by Blown 331
I was qouted $88 for a L.A. sleeve. Ct racing will sleeve my cylinder for $150.I think that includes the sleeve, I am not sure. I probably should have it re-plated, but every time the top-end goes, I will have to pay $200 if the plating was damaged. I will spend more money that way. This way, I will also have a fresh cylinder, and I can have it bored without re-plating it.Originally Posted by sblt500r
You're looking at the situation all wrong. It is true that it'll cost more to repair "if" the top-end goes, so don't let it go. My cylinder is Nikasil plated, so I use that as a scare tactic to make sure it's jetted properly, because I don't want to buy a whole new cylinder or have to go through the replating process. And if you're putting so many hours on the same old piston that the piston finally lets go, you need to change it a little more frequently.Originally Posted by hondatrikesrule22
You can actually just hone your cylinder that you have now even though it is plated and it wont really hurt anything. I have done that before. But the plated cylinder does have its advantages like people above have stated. If you run a clean and oiled air filter, and tear your top end off every so many hrs.(like whatever is recomended in your service manual) and your bore is in good shape and the piston isn't all scuffed up, which it shouldn't be if you do the recomemded inspection at the correct intervals, If the bore and piston is fine just put a new set of rings on and you are good to go. I had the cylinder replated on my old yz 125 and it lasted until I sold it and that was a good 3 yrs. All i did to it was ter the top end off every 25-30 hrs or so and check everything out and install new rings on the piston. Oh and had a squeaky clean air filter in it all the time.
