Thread: Jetting on a Tri Z
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jetting on a Tri Z
    I've been piecing my Z back together and know I'm going to need to rejet. It's stock besides a DG pipe, silencer, and Uni filter. How many should I go up? Would I just change the main? I just don't want to run it being lean right off the bat, rather have it a little too rich and come back down. Thanks.
    85 200x - Torn apart
    May 2002
    Cortland, NY
    1,195
    This will be good info for me too since i'd like to know what I should be running for jets in my 85 with a dg pipe. How do you like your tri z 200xer?
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    Dec 2002
    Spruce Pine, Alabama
    1,263
    I don't have the original jetting specs in front of me, but I would say go up a couple or a few and work your way back if necessary. I'm sure you'll agree that it's best to err on the side of caution.
    '84 ATC70.....my 8-y.o. son's ride
    I've only been able to put around the yard a little bit because I have no airfilter and no exhaust gaskets at that time. Amazingly it started up 2 kick and ran great. Can't wait until I get all my parts and it's all together.
    Rittman, Ohio
    6,276
    What makes you think you have a jetting problem? Run it as is, and monitor the plug.
    Mine went from stock pipe to a Cobra pipe, to Boysen Reeds, to a KN filter, to a DG pipe, with cylinder bores from stock to.080" twice, winter and summer, over about 12 years. Ive run trails all day, and Ive run motocross and even a couple harescrambles. I have rarely fouled plugs other than when needing a bore job, and never melted a piston in it. The only time Ive ever touched the jets was to clean the carb. They are original.
    Dec 2002
    1,263
    Do a plug chop to determine if you need to re-jet. Don't take a chance based solely upon what works for someone else.
