Results 1 to 8 of 8
Thread: Need help! 250r rebuild questions.
    kimmer250r's Avatar
    kimmer250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2002
    North of Swinehart, West of Mik6
    411
    Ok guys, need some motor heads help. Gettin' ready to rebuild the R's motor and can't decide how I want to build it. A guy at the local shop told me to use a 87-89 crank and rod with a 86 piston and a spacer plate to get more mid-range and top-end. I started to order the stuff to do it, but have seen a couple of people that said it will be slower. Should I go for this combo or stick to a stock or overbore application. Any help would be appreciated!
    THERE FROM THE START-HASPIN VET 2002-2003-2004-2005-2006-2007-(missed 08-dang babies)-2009-2010-2011-2012-2013 AND ALL THE REST!
    1985 Big Red
    198? Kawasaki KLT 250
    19?? ATC70
    "Secret Project" Tiny Titan
    2010 Polaris Crew
    G-MAN-1 is offline Just Too Addicted Arm chair racerJust too addicted
    Maybe Be Help Full
    i would have to say that if it runs fine leave it alone. but if it needs rebuilding. then go with new piston and rings,circlips.wrist pin and bearing. and i always go with the WISECO PRO LITE. they are the best. maybe some new reeds. and if u have to do the crank always go stock with that.........
    May 2002
    Southeastern Wisconsin
    3,658
    I'm with G-Man but to answer your question I like the 86 set up the best. Stick with the next size bore with the Pro lite. Also 2-strokes love compression just have the head done for a little more, nothing crazy and get some porting done. I'll be a night and day difference with a good pipe and jetting.
    CENTRAL NY
    1,709
    no need to stroke it...i spanked a few stroker motors, at the local drags with my 86 it was .100 over with a milled and decked head..reeds and a fmf
    May 2002
    3,658
    Freakfixs know what I'm talking about. This will do a lot more than that crank swap.
    Kimmer the 86 is considered the more powerfull motor stick with it
    Guest
    86
    Is there any difference between the '85 and the '86 motors?
    kimmer250r's Avatar
    Mar 2002
    411
    new idea
    Well, I thought it over and I think I might do the LRD 300 sleeve kit. Looks like a sweet kit, but it says it uses a 87-89 cylinder. I'm going to call them and ask if I can use a 86 cylinder, if not I'll sell mine on ebay and buy a 87-89 cylinder. As for the crank, I'll just put new bearings in and a new rod on. Thanks for the info guys!
    1985 Big Red
    19?? ATC70
    2010 Polaris Crew
