I've been looking around on here and i've seen where people have roughed up there steel plates in their clutch. I was wondering how much you rough them up and what you use to rough them up. Any answers will help........Thanks
I rub them on a concrete floor in my garage, in a circular motion. just a little is all you need, then wipe them clean.
IN MY GARAGE:
1984 250r
1986 350x
1986 200x(wifes)
1985 200x fixer upper
1979 110 PARTING OUT
1984 70
http://www.hardcoresledder.com/forum...post&id=155447
'97 ZRT 600 drag sled
'97 ZRT 600 trail sled
'98 ZR 440 sno-pro(wifes)
http://www.hardcoresledder.com/forum...=post&id=79401
Well I picked them up from my local motorcycle shop this morning. I asked the mechanic if i should rough them up. He said that you don't need to because then they will grab to much and be jerky and hard on your clutch.
Originally Posted by oddball3
thats exactly what I do and takes the glaze off them nicely.
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
I wouldnt think that roughing them up would be hard on your clutch, well maybe would chew your fibres up a little quicker. I didnt do it on mine and it doesnt slip so I don't think its abosolutly neccesary.
the only time i ever mess with my clutch metals is if the fibers are otast and i can afford the entire kit. then i use like 600 grit or something and take the burnt oil off them....works pretty good so far...
i did the ones on my Kawi S2, i just used 600 grit sand paper on an orbital sander, then wiped them clean
Curtis
Currently Trikeless- but I have a LT250R
Well I srarted putting my clutch together and my pressure plate broke.Now I have something else to replace. Anyone know how much one costs?
They are cheap on the 'bay. Just remember to tighten the posts equally next time!
i used to sand blast the steel plates with fine walnut shell on my drag banshee's
Ok...well i broke 2 of the "teeth" thingys trying to tighten the nut to the correct amount of pressure. I used a thick steel pipe to stop the pressure plate and insides from spinning and they just broke. Is the insides of the clutch basket suppose to spin freely? If not then somthings wrong. Also my shift lever just kinda dropped when i touched it. It moves freely up and down now. Does that happen when you have the clutch components off? Any answers are appreciated..............Caleb
