Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: My tank restoration job
    Jun 2002
    Mississippi
    2,552
    here is my before and after. it took about 2 hours i used orbital air powered car sander to get the tough stuff. i then went to 400 grit wet sand with soapy water, 600 grit wet sant. then i took a drill mounted buffing wheel and buffed the tank with rubbing compound that you by at walmart.
    mbg75 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    Long Island
    256
    after going through the different stages of sanding, you can apply 4 to 6 coats of mop and glow floor wax. make sure you use fine steel wool between coats and let each coat fully dry. it will give the plastic a high gloss and stays on pretty good. however, if you use any solvent based cleaners, it will remove the coating.
    Back on 2 wheels for now!
    clean 86 350x for sale.
