Question on 250r
I am having a problem with my 250r (85). It will start when pull started by another ATV, but will not start if kicking. It will not idle, you have to keep it running with the throttle. I have a manual and used my ohmeter to check the stator, exciter coil and ignition coil, and all test OK (in the range of acceptable Ohms). When you kick it with the plug out of the motor and grounding out it has weak spark. I feel as though myself and my buddies are having brain farts here, what could I be overlooking? I don't have another CDI and the book says that there is really no way to check it out. Help me as I am feeling retarded right now!
Oh and by the way I had a bad flywheel that was replaced, and the problem just happened last weekend. We were riding and my buddy was on it and we took a break and we just sitting there with our bikes idling (which my 250r did perfectly prior to all this BS) and the 250r just died!
Any help will be greatly appreciated.
06 Yamaha Bruin 4x4
04 TRX Rancher 400 AT 4x4 GScape
86 ATC 250es Big Red
84 ATC 200s (31 yrs running strong)
13 F150 4x4 SuperCrew 5.0
00 Excursion V-10 lifted with 35s
____________________________
Gone
07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
