Results 1 to 14 of 14
Thread: big red won't start
    Jan 2005
    Clarence NY
    51
    Question big red won't start
    A friend was riding my red when next thing I know he is pushing it back, he had shut it off and it won't refire. I checked the power (head light works) , then pulled the plug, and kicked it over (no spark) looked for fuses found a 20 amp strip fuse it's good. I also tried the starter with a charger and it turns over but still no spark. Dose anybody have a clue whats wrong with my red ?
    former wheelers 1983 tri moto 125, 1984 200m, 1986 200x
    new rides 1985 Big red,1985 250sx,tri moto 200
    Apr 2002
    s.w. michigan
    6,498
    tell us more ,,,
    What year bigred ,,, ? If it's a 85 or newer ,,, do you have green nuetral light when trying to start ?
    john
    springville, PA
    6,185
    20 amp? arent they supposed to be 10?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jan 2005
    Clarence NY
    51
    The red is a 1985 it has the light but the blub has been on the list of things to get from the dealer for a while. I tryed goin in and out of 1 and r by rocking back and forth to make sure it was out of gear and it seams to be working properly.
    As for the fuse it is a strip of aluminium looking material that has 20 on it. I have no idea if it is too big just that it is not blown.
    Jim
    Aug 2005
    Sweden
    45
    Did you try a new spark plug? Sometimes itīs simple
    Honda TRX70 -86,
    Honda ATC110 -80
    Honda ATC200 -82
    Kawasaki Tecate -87
    Yamaha WR250F -03
    Yamaha Banshee 350 -02 SOLD
    6 Barossa 250 -04/05 SOLD
    Apr 2002
    s.w. michigan
    6,498
    Fuse is okay
    Quote Originally Posted by the 80s rule
    Jim
    That fuse is for the starter ,,, kinda weird looking but it's okay if it is cranking over.
    I was asking about the green netrual light cuz if the wire down on the lower right hand side of the motor has come off or damaged it will crank over but you won't have spark. Also beside that wire is another one that is for the reverse light indicator. They plug into the side of the motor below the rear foot brake lever and are protected by a little metal cover.
    john
    Jul 2004
    Mud hill. close to water !
    3,658
    When you check for spark.. you ARE touching the tip of the plug to the cylinder right ? ( just have to make sure !! lol )
    Currently :
    Jan 2005
    Clarence NY
    51
    I got the bulb replaced it dosn't light up. The only way the starter works is if I use a 50 amp charger right to the starter. I did that to see if the starter worked it did but I still have no spark. I am grounding the plug because I have made that mistake before. I'm still perplexed.
    Apr 2002
    s.w. michigan
    6,498
    well,,,
    Have you checked those wires I spoke of in my above posting ???
    You need to get a green nutral for sure before you will have spark.
    john
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    Nine chances out of ten the two wires he is talking about will solve your problem. They have a bad habit of vibrating off and killing the engine. Just undo the small black plate, or even just bend it down out of the way and push the two wires back into the sockets and try again. The plate is by the rear brake pedal held on with a 8mm headed bolt.
    Jan 2005
    Clarence NY
    51
    The red is at my shop I'll have to try tomorrow. Thanks for the help[ hope thats all it is.
    Jim
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    Maybe if you get some one to push it while * kick it into first and give it some throttle and get it going then * might be able to check all the stuff if * can get it running. Just my 2 cents thought
    Jan 2005
    Clarence NY
    51
    The green wire was the problem. I cleaned it best I could with sandpaper and put some dielectric grease on it and the netrual light came on. Now all is well and I am a happy rider again. Thank you to all who took the time to help me.
    Jim
    Apr 2002
    s.w. michigan
    6,498
    Great !
    If memory serves me correct ,,, the other wire (reverse) can be off and dangling and you will still have spark ( but of course no reverse light ).
    john
