Results 1 to 15 of 16
Thread: Exhaust repacking
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Exhaust repacking
    Do older Bassani exhaust pipes ever need repacking on 4 strokes?
    Let's hear it.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Apr 2002
    s.w. michigan
    6,498
    probbly ,,,
    Nothing I know of is maintence free ,,,
    I repacked a cobra muffle a couple of weeks ago. What a Bit&$ of a time I had getting it apart.
    john
    Fresno Ca
    2,695
    Yes they do need to be repacked, i recomend doing it often (every 100 hours) and just using the cheep $10 sheet of packing. That way you keep on doing it and its easyer to pull appart. I change mine about every 8 or 9 monts.
    crackshot's Avatar
    Idaho
    1,024
    where can you get packing material? it's the same as the 2 stroke stuff isn't it?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Fresno Ca
    2,695
    Your local shop should have it on the shelf. I belive its the same as 2 stroke but i'm not positive.
    springville, PA
    6,185
    What is involved when repacking the exhaust? I thought the part that got repacked was the spark arrestor and my bassani doesnt have one.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I just did my Cobra muffler on my 225 today.I bought a sheat af packing of fiberglass and some mechanics wire to hold it on.If you rap the mechanics wire on the rite way the packing should stay on for awile.
    arizona
    550
    is it possible to repack a dg exhaust? mine wont come off.
    Mar 2004
    Gettysburg PA
    498
    What does the packing in silencers do? Is it just to keep the noise levels down or is it suposed to try n catch most of the exess gas and oil?
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    Fresno Ca
    2,695
    The packing does several things one is cut down the sound, the other is give more power by giving a more direct route out. After a while it get cloged with carbon and the fiberglas brakes down. The dg's for 350x's need to have packing. you realy just have to play with them to get them to work loose. WD40 and a penetrating oil of your choice should help alot, The more dificult ones i normaly let the end soak in deissel (sp?) for a night then go to work.
    Spark arrestors have nothing to do with packing, a spark arrestor is all about screaning out the exhaust so a flame or spark cant exit the exhaust.
    Edog is right, you need to take the old core and make shure all the holes and everything is nice and cleand out, then you take the sheet of packing and wrap it around the core, and use wire of some sort to hold it onto the core.
    Ontario, Canada
    457
    i just use the insulation from the under side of a car/truck hood...works fine and is cheap!!!
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Fresno Ca
    2,695
    Quote Originally Posted by TtownJoeShow
    Dont use that, just use the correct stuff, its only $5-10 a sheet, how much cheaper do you want it?
    Ontario, Canada
    457
    lol yeah i guess, i have never bought it so i didn't know the price and its kinda a hasle to goto the bike shop its like half an hour away
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    crackshot's Avatar
    Idaho
    1,024
    Ok got some packing removed the screws. How the hell can you get the baffle out without destroying anything.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    crackshot's Avatar
    Idaho
    1,024
    nevermind. I tack welded a big ass bolt on the silencer, used a slide and WHAMMO. Came right out. thanks for all the help.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
