Results 1 to 15 of 18
Thread: Pictures of the inverted KTM85SX forks for my Z
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Ok, heres the pictures of the new forks.
    Pic #1: One of the '04 KTM85SX front forks leaning up against my 'mockup' Tri-Z. Camera was having a hard time with the low light in the shop this evening so its a little bit blurry. Checkout how nice and fat the lower portion is....
    Pic #2: Both forks side by side. At first glance the 85SX forks look to be shorter then the Tri-Z forks, over all they are. Once you look closer though, you'll realise that from the top to the axle mount hole is the same
    Pic #3: About the same as #2, better lighting.
    Pic #4: I probably took 25 pictures trying to get this to show up and this was about the best one. This is the metric measuring calipers over the Tri-Z forks. The calipers are set to the same size diameter as the KTM forks at the small end which is 43mm (Coincidently the same size diameter as the conventional CR500 forks). Z forks are 35mm in diameter, so the KTMs are quite a bit larger.
    Pic #5: This is a picture of the axle holes, I haven't took the Z axle out yet to compare the two exactly, but I dont think there is as big of a difference as i was thinking. Not sure what I'm going to do about wheel bearings yet. Probably order a set of KTM bearings and see how they fit into the Z hub and then go from there with possibly boring the hub out to fit a larger OD bearing or making an aluminum bushing and welding it in, depending on which way I have to go.
    Pic #6: The top clamp that I got with my CR500 laegers conversion parts. The clamps I'm making will be based off of this. I'm making some steel ones to start with and then will make aluminum ones in this same style at a later date. Hopefully CNC machined billet ones in the future.
    Attached Thumbnails Attached Thumbnails 85SXfork.jpg   Forks1.jpg   Forks2.jpg   forkdiameter1.jpg   forks-axlehole.jpg   Leagerclamps.jpg
    Live Oak, FL
    15,069
    Heres the last ones of the brake calipers.
    The nice new shiny silver looking one is the stock KTM85SX front caliper. It'll of course fit up nice with the forks, but as you can see its very, very small. Even though its a dual piston design instead of a single like the Z caliper it probably has half the pad area, so I know it wont brake near as well. I'm probably going to have to make up some custom bracketry to make the Z caliper (Or possibly something else) fit when it comes time. Depending of course on what needs to be done with the brake disc and stuff to keep the alignment right.
    Attached Thumbnails Attached Thumbnails brakecalipers.jpg   brakecalipers2.jpg
    Ontario, CANADA
    4,538
    That is awesome Billy! I am looking forward to seeing this massive conversion move forward. I would like you you said use the Z brake system other than the SX one. Looks like this could turn into a very good project, I am very interested on how this will turn out. Good luck Billy!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    Bill, If it were me, I would not put that Z caliper on it. Your gonna have this high tech frontend on it, the least you can do is update the braking system. You allready have all them new nissin masters.. Look on ebay at streetbike calipers. Awesome looks and awesome performance. Plus you can usually pick them up at not too bad of a price.
    Good to see the project taking off, I think you have put the most thought into the frontend conversion then anyone else (including the people who have done it).
    Nov 2004
    Waterloo IL
    2,701
    When I first saw your thread title I thought you were puting forks from an 85 250SX on a TRI-Z, I was like WTF?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Blown 331
    Same here!
    Live Oak, FL
    15,069
    @ Kintore:
    Thanks! Its gonna take some time and some serious tinkering but I think I'll have it worked out. The first set of tripples i think should be done in 3-4 weeks. I was thinking about 2 weeks but my dad seized the lathe today working on the round clamping pieces while I was taking my mom to the chiropractor this morning. Hopefully he can get it unstuck and we can get back working on it. I have to order some holesaws and a few other misc things either this week or next to help get the tripples setup.
    @ Jared:
    I agree with you on the caliper thing. It needs to be updated to something else. I hadn't thought of a street bike caliper, but your right that would be pretty cool and they do work good. The only thing is, their kind of big, might have a problem with it fitting in the wheel. My thought was, that since I know the KTM125SX front forks are the same diameter as these but longer, maybe one of the front calipers off of it or something larger (Like a 250+) Would work too. Its kind of a long shot but it might work. I also just realised I have an old CR500 front caliper off of the inverted forks I first started messing with back on the 500X. Thats a pretty beefy caliper and it was a twin piston design. Seems like the mounting holes were similar but I'll have to investigate that a little bit more.
    @ Huffa and Blown331
    I never thought of that, I guess I should change the title huh?
    Mar 2004
    North Central Ohio!!
    2,712
    Billy, since your working on the front anyhow and building new triples, maybe you should think about changing the rake. Wasn't the long rake on the Z what made it handle less agile than the other 250's? I know Tim had told me that he runs his forks up in the triples for that reason (pretty sure). Might be something to think about.
    Live Oak, FL
    15,069
    Derrick, I was actually thinking of increasing the wheelbase slightly (Moving the forks further ahead) so that I would retain my same turning radius as I do now. If I left them in the stock posistion, I would have less turning room because of the larger diameter forks. Changing the actual rake in the clamps would be tricky...you'd have to mount the stem in the bottom and top clamps at some sort of an angle. It could be done I guess but I'm not totally sure how to go about doing it.
    Feb 2005
    washington
    58
    could you give us some more pics of the steel clamps you have and the thinkness of plate used please
    Mar 2005
    ma
    988
    i might have missed something but why use 80 forks? won't they be to weak or soft? a triz weights a bit more than an 80 mx bike! unless you plan on changing the springs
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Live Oak, FL
    15,069
    The 85 forks are already the correct length. Any thing from a 250 or 125cc bike has to be shortened. Yes, I will have to change the springs to a custom weight but thats alot easier then tototally dissasembling the forks and cutting down the fork tubes, the springs, the dampening rod, the fork cartridge, re-tapping the end of the dampeing rod, re-drilling the valving holes, ect ect ect.
    The steel clamps are not done yet, but when they are I will post some pictures. They are going to be pretty thick and heavy to start off with.
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    What is the travel difference between the two fork set ups?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Jun 2004
    Pyeongtaek, South Korea
    474
    Quote Originally Posted by LonesomeTriZ
    Tri-Z - 10.0 inches
    85SX - 10.83 inches
    Not much basically, but the quantum leap in damping technology is worth it. Not to mention it's gonna look trick! I've seen an 85 250R with YZ80 forks, and it was sweet.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Jan 2005
    5,301
    Food point. I was considering YZ 80 forks myself. But it looks as though this way is a little better in some ways.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
