Results 1 to 2 of 2
Thread: Coolant backfill on Tecate 3
    Sep 2005
    MICHIGAN
    2,027
    1986 T3 coolant resevoir. Mine is missing. Is the backfill tank necessary?
    The coolant seemed an inch or two low after I got it, but there is also a slight leak on the waterpump cover at the coolant drain bolt. Is this bolt usually gasketed?
    http://home.att.net/~nd4speed/clutch.JPG
    May 2002
    Texas
    2,670
    I ran mine for a few years without the coolant res.
    There's just a washer underneath the water pump screw.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
