Thread: 86 tecate 3 forks leaking
    Sep 2005
    MICHIGAN
    2,027
    Do any of you guys rebuild your own forks? How much does it cost to have them rebuilt (usually)?
    Jan 2005
    Great Bend
    704
    these guys can rebuild your forks for about 85 bucks and that isnt bad. LIECHTI RACING SUSPENSION SYSTEMS (go to yahoo and put this in)
    rebuilding standard style forks is really not that hard. if everything goes right and you take your time you could have them rebuilt in about 2 hours.
    if ya need some help PM me and I will explain how to do it.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Sep 2005
    MICHIGAN
    2,027
    Sounds like I should have it done locally. I probably wont be doing this job myself as $85 seems reasonable.
    Why are they leaking at the bottom if this is common? I have not looked but I know there is a drain bolt there.
    86 T3
    84 T3
    86 KX250
    Jan 2005
    Great Bend
    704
    if its leaking at the bottom there are 2 things you need to look at.
    1: at the verybottom of the forks there is a bolt that holds the suspension valving rod in place on the inside of the fork, if it is leaking from there tighten it up to about 13 to 15lb-ft of torque, not a whole lot or you strip it out.
    2: at the bottom of the forks the side away from the axle you will see a bolt, again if it is leaking from there then you need to tighten it up to about 10lb-ft torque.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
