Results 1 to 15 of 24
Thread: gas tank clean repair?
    Aug 2005
    SW Iowa
    524
    Question gas tank clean repair?
    what's best way to clean the inside of tank before treating?
    Randolph NY
    597
    How cheap are you? that is the question!
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by bigred1
    You actually don't need to clean it that well if you treat it with Red-Kote. If your planning on using standard tank cream you might as well just throw your money away. Another option would be to buy my tank. lmao
    Do a forum search for gas tank posted by jeswinehart. I am sure a few others will vouch for his ability here.
    Howdy
    Aug 2005
    SW Iowa
    524
    How much is red koat? where might I find it?
    Aug 2005
    SW Iowa
    524
    to the ? of how cheap am I well if money wasn't the object that it is I would just buy another one that is unless redkoat cost as much.
    Randolph NY
    597
    if i was you bigred i would see how much howdy wants for that tank he has, he allways gets good feedback on his products from the people he sells them to.
    Anaheim, CA
    517
    havent had any problems with the kreame i used in my tank and it was only 28.00 for a three part treatment. so you may want to "throw away" $30.00 on that kreame stuff if you know how to follow directions exactly it should work fine. if you cut corners then the results will probably suck
    83 250R
    91 CR125R
    Howdy's Avatar
    Celina, Ohio
    10,079
    http://cgi.ebay.com/FUEL-TANK-RELINE...QQcmdZViewItem
    I just bought 4 quarts from this seller. I highly recommend him. If you buy from him make sure you tell him "Howdyfrom3wheelerworld" recommended him. Another option would be to look at a local independant auto parts place. That is where John ( Jeswinehart ) gets his. I would have done this myself, but none of them around here even heard of the stuff.
    Your other to options would be to see if John can get you a can, or have someone do it for you.
    Howdy
    Aug 2005
    SW Iowa
    524
    I have done busines with him he's a good guy and a great help. I'm a family man just trying to save a penny where and if I can. like I said not sure how much koating is
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Somekindofjerk
    Bigred1 has done buisness with me in the past. Very easy to work with.
    The tank I have is already clean on the inside ( wanting $45 + shipping ). Heck I can probably get a vid of the inside with my helmet cam. I can even sweeten the deal, I can line it before I ship it and then you won't have to worry about rust in the future. Same price on the tank either way ( lined or as it is ).
    Howdy
    Aug 2005
    SW Iowa
    524
    thanks for the input guys!
    Jun 2004
    Pyeongtaek, South Korea
    474
    HAHA! According to the manufacturer's name, I make that stuff! If only I had known that I make it, I would have hooked y'all up, but someone beat me to it. Sometimes I am amazed at what I can accomplish without knowing it.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by willcamach
    I have used the kreem too for a number of tanks and had no problems but if the Red Coat is easier I'll give that a shot. Even though it says just to get the heavy loose rust off I'd rather add a step and get as much out as possible.
    I got a tank coming my way very soon that needs a Red Coat job bad so I'm anxious to try it.
    I wouldn't put Kreem down to the level of being junk and as said if you follow the steps you should have no problem. I'll have to look inside my Nighthawk 700S tank that I did years ago, just to see how it's holding up, since I didn't peek in there for a long time.
    Howdy's Avatar
    Celina, Ohio
    10,079
    I had a Nice 350x tank that I wanted to get repainted. The inside was like new, but I still wanted to kream it to protect it from future rusting ( The custom paint job I was going to get was going to cost mega $$ ). The painter even recommended that I coat the inside of the tank. So I took it to a radiator shop and had them dip it for me. I then followed this up with the whole kream kit, I followed the instructions to the letter. The painter told me to drop it off in 2 weeks ( he was busy right then ). When I took it to the painter the kream was already peeling. I was not a happy camper. I took it back home and could see it was peeling all over ( what you could see ). I hadn't even put gas in it yet. I spend a few days trying to get the rest of the kream out ( one little sliver at a time ). Anyway after about 3-4 days working on it I gave up, I won't say what happened to the tank ( I was highly pissed ), but I can safely say it was never able to be installed on a machine again.
    Now I tried Red-Coat on a rusty and holy tank and was very much impressed. With just 1 quart of Red-Coat I was able to coat a total of 4 gas tanks ( 2- 90 / 110's and 2 - 200s style tanks, and I still have a slight amount in the can.
    To prep the tank all I did was to put a couple dozen 5/16 nuts in it and shake the living heck out of it. I then removed the nuts and all the loose rust. I made sure it was dry and poured the red-coat in it. I rotated the tank as the directions said to do and then poured the remainder coat out. I found out I did have some holes in the tank when the red-coat dripped out. I quickly cleaned it off and taped over the hole. The tank sealed up on the first coating and it holds gas very well. Not to mention the fuel comes out looking like it did when it was put in ( CLEAN ). I am sold on the stuff now. You can use what ever you want, but I know what I am going to be using from now on.
    Howdy
    Mar 2005
    Alberta
    503
    I have never used Red Kote or Kreem on tanks, so I was wondering, what do you do with the petcock drain?
    How do you stop it from getting plugged up with these "treatments"?
    A whole bunch of trikes.
