Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: gas tank clean repair?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by freewheel3
    I have never used Red Kote or Kreem on tanks, so I was wondering, what do you do with the petcock drain?
    How do you stop it from getting plugged up with these "treatments"?
    I wondered this same question before I did the coating. What I did was to put a piece of tape over the end of it. I did remove the filter screens on the 200s style. Once I got the tank rotated enough to coat the whole inside I simply removed the tape and drained the excess out of the tank via the drain hole ( putting it back into the can ). You do have to tilt the tank so it all runs towards the drain. Once it was done draining I simply wiped the end of the drain off and let it dry. The Red-Kote goes on so thin enough that the filter does fit back in the drain. It's snug, but it does fit.
    Howdy
    Aug 2005
    HI
    1,575
    I have used POR15 on my tank and it seems as eas yas all this Kream treatment. Prettymuch tape the holes, shake around then emtpy. Easy as 1, 2, 3. Only problem i had was i got the stuff in and around the top of the gas tank so i couldn't rotate the cap. That was my only problem.(Edit) This is just another option to Kream.
    Rest in peace Rex Carlson
    Mar 2005
    Alberta
    503
    Quote Originally Posted by Howdy
    Howdy
    Thanks for the info Howdy.
    A whole bunch of trikes.
    Aug 2005
    SW Iowa
    524
    can J-B weld be used to patch small holes like the size of the tip of an ink pen on a gas tank?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by bigred1
    Yes, it can be. But I have never had any luck with it lasting more than 4-5 months.
    Howdy
    Randolph NY
    597
    iv found that a small(90amp)mig works good or brazing. the only backfire to brazing is all the heat makes your paint peel off, but mig works very well!
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Somekindofjerk
    Be 100% sure you have all the tank washed out and all the fumes removed before doing this. I know a guy that made a round tank because he didn't wash his out. Can you say: KABOMMMM! I sold him another tank.
    Howdy
    Randolph NY
    597
    Howdy
    That just makes my day, poor guy!
    Back in Happy Valley
    833
    Is the red-coat stuff that comes in a silver and red can i think its about 35.00 for a quart? My local Honda shop tried to sell me some but i wasn't sure if it would work well or not, i'd like to line my X's tank as it has some slight suface rust from all of the moisture down here...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
