Results 1 to 15 of 18
Thread: 81-82 R?
    Sep 2005
    Massachusetts
    1,272
    81-82 R?
    Theres been a bunch of 82 R's in my local wantad. Cheap too. I'm talking 600 for an all original R. Can anyone tell me what these are like? Suspension wise, hows the power, is it good for trails? Thanks.
    Ontario, Canada
    457
    some of the '81's had a tripmeter, elec start AND Reverse!!
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Mar 2005
    overton, PA
    5,257
    81 250r? had trip meter, e start and revrse? i never heard this before,
    Jul 2004
    Mud hill. close to water !
    3,658
    No reverse.. on ANY R
    Currently :
    Ontario, Canada
    457
    it's in the clymer manual
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    Jul 2004
    3,658
    None of the honda 250 R's have electric start or reverse.. guaranteed... check again
    Currently :
    May 2005
    Dorset United Kingdom
    1,408
    Afraid not mate,
    No R had elec start-kick only
    None had reverse-your feet do this job
    And the tripmeter was not standard equipment
    Will
    Last edited by slothminx; 10-07-2005 at 11:33 AM. Reason: BRH and me posted at the same time DOH!
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Jan 2005
    Great Bend
    704
    I had an 82R that was totally awesome in the trails. as for power, real smooth and predictible, suspension not the best by todays standards or even the 85-86R standards but it is good enough for moderate trail riding. the set up that I used was it had a stock pipe with an aftermarket silencer, stock gearing, 20" tires. the engine had a .50 over piston in but beyond that it was really not modified except for a K&N filter. with this set up with the 20" tires and the stock gearing it was not that fast on top end but it was real billy goatish in the trails, motor would spin quick rocketing up hills or flyin outta corners which is what you want in a good trail bike.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Sep 2005
    Massachusetts
    1,272
    Thanks for the response atcwrench. The thing i was worried about mostly was the suspension. Seeing that its a 82. How much suspension clearance is there? Some of my trails are kinda rocky. I don't want to bouncing all over the place. Do you think its possible to bolt up 85-86 R forks and rear suspension? Thanks.
    Jan 2005
    Great Bend
    704
    negative on the suspension swap, the 85 middle triple tree tube is too long for the 81-82R frame tube, the rear suspension on an 81-82R is a linkless design as the 83-86R have a link suspension set up. if your terrrain is kinda rocky go back with a set of 22" tires which is stock and change the front sprocket from a 13 tooth(stock) to a 12 tooth. this will shorten your gearing and make it feel like it has more grunt than it really has.
    to help the suspension out rebuild to forks if they need it and put in thicker fork oil from belray and install progressive rate springs, rear suspension, if the shock still has a good charge on it and still has oil in it, install a progressive rate spring as well. the suspension will feel kind soft on the real short travel but as it starts to go up in travel the spring stiffens up and works like a cheap link set up.
    you can get the springs at www.bikebandit.com at a reasonable price
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Mar 2005
    overton, PA
    5,257
    they kinda handle like a lighter more powered 250sx, a lil bouncy but not a bad ri=de for its age, better than a non suspended model.
    Sep 2005
    Massachusetts
    1,272
    Excellent thanks. Maybe i'll call the guy tomorrow. $600 bucks isnt bad. He says starts first kick. All original. Ready to go. $600 b/o. If its in awesome condition then ill make out like a bandit
    Mar 2005
    overton, PA
    5,257
    offer him 4 or so and deal if ya got the cash and the desire to ride.
    Sep 2005
    Lipetsk, Russia
    2,824
    I'm thinking about getting one of the air-cooled ATC250R's too... It's a 1982 I think. Where the hell are you, to get an OEM 250R for 600??
    Sep 2005
    Massachusetts
    1,272
    Massachusetts. This is the second all original one ive seen in the last 2 weeks going for $600. I definatly got the desire to ride. Been riding for 10 years and still going strong. I just need a trike
