Results 1 to 7 of 7
Thread: ? about 200s timing and backfiring
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    went to ride my 200s today and it wouldn't idle, just dies. It's always been kinda screwed up. I rebuilt the carb and replaced the carb to cylinder intake tract thinking airleak, but that didn't help. Today it was backfiring really bad too, so I checked the timing since the screws had been out before I bought it. Is it supposed to be timed to the F or the T mark on the flywheel? I guessed the F since my manual was at home and the trike is at my Dad's house.
    Also it has this wierd miss, it will idle and then pop back through the carb and then the idle speed will change, sometimes it will die. I've tried adjusting the air screw. Is that a bad valve or what? I adjusted the valves when I got it, and the cam chain a couple of times. I just want to make sure it isn't something simple before I take the top end off.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Jan 2005
    RI
    2,530
    Youre supposed to use the T mark to time the cam, not the F. If you have AIM, let me know, and ill send you the manual in pdf format.
    toronto , ont
    6
    i'm having the same problems with my 200 m... back firing at idle and when u rev it up a bit.. need help...
    Jul 2004
    Blue Ridge Mountains
    141
    I had similar trouble back in the day with my FatCat (TR200) after a re assembly... I was one tooth off when I lined up the cam timing marks. It would start up very easily but it would back fire during deceleration and of course it lacked power.
    Double check your marks...
    Sargon
    ** '85 Yama- 225DX (wheelie machine)
    ** '85 350X (current project)
    ** '86 TR200 FATCAT (Old Faithful)
    ** '91 KDX250 (The Green Machine)
    Apr 2006
    Crestview, Florida
    2,429
    you use the F to align the spark advancer. sounds like the valves are adjusted wrong or the slow jet is clogging up.
    Rides
    85 ATC350X
    85 ATC200X
    Ironton/Ohio
    40
    Ok guys, I am a total idiot, that is clear.. but, how do you check the timing? I think that is my problem with my 200e, any of you all profesionals have the time to explain?
    Honda 1983 200e Big Red - (in process of being a beast)
    Suzuki 2005 Ltz-400 - (love dem four-wheela's!)
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    I use a digital timing light, powered by a battery charger.
    That lets me check the timing and set the rpm.
