Im looking for the stock bore size for a 81 tri-moto 175 along with Maximum/minimum cylinder wear size
Thanks.
Thanks.
1985 Tri-Z-
Originally Posted by mywifeknowseverything
Stock bore is 66mm, I believe. I'll post the limits tomorrow if no one else has put them up by then.
1985 Yamaha YTM225DX
2014 Yamaha WR450F
2008 Yamaha TW200
1975 Honda CB400F
Bore - 66mm
Taper limit - .05mm
Out of round limit - .01mm
Cyl. to piston clearance - .040 to .045mm
Bore wear limit - 66.1 mm
Ring gap - .30 to .50mm
2014 Yamaha WR450F
2008 Yamaha TW200
1975 Honda CB400F
Thanks a ton...will make it much easier!
1985 Tri-Z-
