Will the swingarm off of a 350x fit on a 200x? Does any know if the 350 is longer?
Thanks
Thanks
No it will not fit.
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
Early 250r swingers will fit other than that aftermarket swingers and stock are all you can use.
I would like to see an early 250R swinger on a 200X. all atc R's have a split front design so it can attach to a bracket that bolted to the motor, the 200X swinger is solid all the way across
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
I have a early 250r swingarm right here that is the same as the 200x. I can tell by the original paint color of the swingers. I'm almost 100% sure that if fits and will go see right now and post a pic.
Edit: I may be wrong.
Thanks for the help. Let me know what you find out about the 250r. I was thinking I may just see what a welding shop would charge to extend it. I need to learn to weld. So I can do stuff like that.
i once had a 85 200x swingarm mounted in my 350x at one point, it was too narrow so i had to cut some spacer's to center it.
my trikes:
1983 honda atc 200x-k&n filter
2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
1991 chevy s10 4x4 350v8.
1986 250sx
YES its fast NO you cant ride it.
So does that mean the 350x would be to wide?
