Results 1 to 9 of 9
Thread: 85 250R ATC sputtering
    Oct 2005
    Ca
    52
    Question 85 250R ATC sputtering
    Hi all, Great site here
    I have a 85 250r ATC and having some problems. After I start the bike a let it warm up and go for a ride, when I open the throttle, it starts to sputter. It starts just after I start in the powerband. Any ideas what may be causing this? It still hauls butt, just embarrassing when it sputters racing in the dunes. It happens on dunes pavement or dirt. Thanks all for you help
    Jan 2004
    Palmetto,Florida
    2,300
    Sounds like the main jet...gap the plug at .02..then try it
    "07" DR650 Suzuki Dual Sport
    Yardbird's Avatar
    Yardbird is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2003
    Clantee, CA SoCal
    288
    Try checking your float level.
    1985 ATC350X (Original owner for 21 years and counting!)
    1986 ATC500R W.I.P.
    myspace.com/duner67
    Oct 2005
    nj
    15
    try turning the choke on halfway or even all the way cause my friends yz80 has the same problem but its his jet and he turns the choke on to go riding
    Richland WA
    808
    too rich or weak ignition or both. if it wont handle more than a 0.020" plug gap, the ignition is weak. Should jump a bright white spark at night when arced to the spark plug tip. Stuff a piece of wire in the plug cap and use that to jump to the spark plug.
    A properly operating stock ignition system will handle a spark plug gap of 0.045 - 0.050". Ive modified my stock ignition and it runs at 0.065" + gap.
    Carb-, drain the fuel bowl and measure the volume, it should be somewhere around 40 - 45 cc. if its more than that, it may be flooding due to a bad float, float needle or bad needle seat. If the seat is bad, new carb time. $120.00
    If not that, then jetting.
    Galloway N.J.
    68
    Check the top jet. The main jet operates all the time and the needle is from like zero throttle to a little less than 3/4 throttle. The top jet is used mainly from 3/4 to full throttle.
    1986 200x- Not running as of now
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by Racedude48
    I know of the mixture screw (idle-1/4), the needle (1/4-3/4) and the main (3/4-WOT). There is a pilot jet too sometimes (low end) but what is a top jet?
    Galloway N.J.
    68
    Its sometimes called a power jet. its connected to the tube that connects to the bottom of the bowl. And its the same tube that you read ** float levels with.
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by shawn3169
    Same exact thing here! It's really cold and the YZ 80 doesn't want to get into the powerband so I just pull out the choke and it's fine.
