Results 1 to 7 of 7
Thread: Which honda atc had a bolt on steering stem?
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    I bought an 86 lower tripple and steering stem for my 86200x because I needed a new steering stem. I went to put the new lower tripple on the forks, and it wouldnt fit. After that I noticed the lower tripple tree that came on the trike had a bolt on steering stem, not a pressed in one like the new lower tripple I received. Do I have a 350x front end on my 200x?
    Would the 200x tripple worrk if I took it to a machine shop and had thefork clamps bored out, or wouldnt it hold?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Galloway N.J.
    68
    the 200x has a bolt at the top of the tripple tree.
    1986 200x- Not running as of now
    Central PA
    1,952
    No, the bottom tripple has a bolt running through it to keep the steering stem clamped to the bottom tripple.
    PastRides
    SOON MY PRECIOUS!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    1985 200X has one.
    Central PA
    1,952
    Did the 85 200x have bigger forks though? Why would they make the fork diameter smaller on the 86 if they upgraded everything else?
    PastRides
    SOON MY PRECIOUS!
    Sep 2005
    Chittenango, New York
    84
    Could you take a picture im having trouble visualizing what your talking about.
    but it sounds like what you are saying is that the triple tree that is currently on has a bolt through the bottom?
    1984 ATC 200s
    1985 ATC 250sx
    Rutland Vermont
    194
    200x triple trees do have the bolt holding the lower clamp to the stem. I'm not sure if the 350x or the 250r have them or not. Measure the diameter of the fork holes in the upper and lower trees and I will see what my forks are.
