honda 83 atc 110 points or cdi
- any one know if the points setup will bolt onto the cdi style head assuming you have all of the hardware - including the different mounting plate?
- i need this because i have a crank with no threading to hold the flywheel in place and i keep rounding crank keys.
- i have a new crank but it would be alot less work for me to just change out the motor; i have everything except the points ignition for a points setup motor
- The cdi motor ran for a while but now i just cant get good spark, and i dont think a die would be very effective. i am assuming to get it done right i would have to remove the crank and at that point i might as well just put in a new crank (since i have one)
- My question really is; are the points as reliable as the cdi or should i stick with the cdi??
-Thanks for reading and answering.
83 atc 110
85 big red 250es
95 Kawasaki Mojave
71 SL70 - basket case - picked up 9/9/08
as soon as you're born you start dying so you might as well have a good time - John McCrea
