Is the ytm200EK have the same bottom end as the ytm225dx. Will the 225 sleeve fit in the 200 cases.![]()
Nope, the 225 cylinder does not fit in the 200. You may be able to bore out the 200 case to have it fit though. I don't think the bottom ends are 100% the same either. If I remember right the shaft output area is different or something but hopefully someone else will know for sure.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
The 225 has a longer stroke as well. You would have to swap the crank too I would think.
Thanks for all the info. Cory were the gears in that bottom end of yours salvageable? Wes
I have a 225dx bottomend if you need one.Originally Posted by 225dx
Howdy
You can get Howdy's if you want instead of my tranny gears. It'll save you the trouble of switching everything over.![]()
