Results 1 to 3 of 3
Thread: 2 Q's, Keihin Carb's and Riser Plates
    Ontario, Canada
    457
    Question 2 Q's, Keihin Carb's and Riser Plates
    hey,
    does anybody know if the tops (where the cable goes through) for the Keihin PJ's are all the same, well like 30mm - 36mm bores?
    # 2; what charicteristics do Riserplates cause, ie low end, mid, top?
    i thank you for your time!
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Mar 2004
    Eastvale, CA
    630
    On most carbs, everything is bigger or smaller from one size to another, so no, the caps are not going to be interchangeable from a 30mm to a 36mm carb. As for your riser plate question???I think you're talking about a reed spacer, which in theory, is supposed to add more bottom to mid range, but the difference is minimal at best.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Ontario, Canada
    457
    hmm okay cool, thanks!
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
