Results 1 to 15 of 17
Thread: how do you guys like tecate 4's?
    arizona
    550
    i might buy one soon, anything i should know? pro's? cons? good years?
    Rod's Avatar
    Rod is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    grants pass, or
    235
    don't know much execpt they are one of the coolest looking quads in my opnion. I hear they haul tail too. If it is a good deal I say get it .
    1985 tri-z needs a little work
    2003 400ex
    1999 yamaha warrior, for sale
    2006 yamaha raptor 700
    1986 atc 500r wrecked & mostly parted out
    1984 yamaha pw50
    arizona
    550
    verry good deal actually, trade my 84r plus a lil cash for a ported, piped, and intaked t4. sounds amazing trade to me. id like to get into amateur racing if i could, is there an age limit or something?
    il keep you guys posted.
    Sep 2005
    Massachusetts
    1,272
    The t4 was rated at 41 hp I think. It was the fastest of the 250 quads. I think it was radared at 77mph. It had more power than the trx250r and the lt250r also. They are really nice. If I could get ahold of one for cheap I would snatch it up in a heart beat. But I've never seen them go for less than $1600.
    Jackson MI
    1,688
    The front suspention will beat you up, after market front shocks are a must. The cylinders are nicasil, & are almost always worn out. I have 3- t-4 cylinders that need to be replated, or sleeved. Another thing to look for is the front of the frames get bent, from people hitting trees with one side or the other. Also the rear shocks don't last, the two t-4's I have had I rebuilt the shocks & they still leaked (the outer shock tubes were worn out). The cool thing is I used a banshee rear shock on mine. I put a 86 honda 250-R engine on mine, it was cheeper for me to put the honda motor on than to sleeve the origional cylinder. It's actually the wife's ride. They are super cool looking Quads.
    May 2002
    Texas
    2,670
    Not much choice on good or bad years either. 87 & 88 only. Some claim 89, but they are left over 88's. As far as I know there are only officially two year models. The big talk about them back in the day was that in stock trim they were too narrow compared to the other quads, but had the most powerful mill.
    I'd probably make the same trade. An 84 R & cash for Tecate-4.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    arizona
    550
    jeez these bikes sound like beasts, il do everything in my power to get it. thanks for the info guys, i learned alot.
    btw, the one im looking at hasnt been bored or replated, would it be cheaper to have l.a. sleeve repress a cast iron sleeve into it or re nikasil the walls?
    Jun 2004
    Pyeongtaek, South Korea
    474
    If you are looking for info about Tecates, head over to kawieriders.com. They have a Tecate-specific forum. For engine work, most shops have no clue how to tune them, so contact Magoo, KingofKawies, or David Roberts over there. They are the resident engine builders.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Newfoundland
    5,280
    Don't sleeve it, cheaper in the long run to replate a cylinder then to bore it, have it sleeved and the bore it to spec again. I found out the hard way by having my two T3 cylinders bored and sleeved...I'd really like a nikisel lined cylinder for mine now.
    arizona
    550
    so how much does a descent tec 4 go for? if this deal doesnt fall through, id still want to get a late 80's to early 90's 250 2 stroke atv, and with my price range, ive been looking at lt250s and tecates.
    in personal experiance, which is more reliable? i want to get into amateur racing, but i spend most of my time up in the mountains on dirt roads, or in snow.
    how much am i looking to fork over for either of these bikes? ive seen the prices all over the place on ebay, but here in az bikes are more expensive used.
    Sep 2005
    Massachusetts
    1,272
    Around here a decent lt250r goes for about $2200-$2500. Tecates on the other hand are usually $2500-$3000+. If your looking for a trx250r you will spend $3000-$4000+. I've seen some 86-87 tecate 3's go for $3500.... I was also thinking about a lt250r a long time ago. They always say look for cracks around the front suspension area. Look for cracks around the swingarm too. Expecially the 85-86 models. The 87+ models had the powervalved motors and a 6 speed tranny. 1987 Lt250rs are harder to find parts for. I guess you could call the '87 lt250r the odd ball because they had some changes that only that year had. Kinda like the 1987 LT500R. They had 6 head studs instead of 7 or something like that (I need to re-read my old resources). And I think in 1990 the rear suspension was totally changed. It's alot better than the older models I have heard. There was a cool website about the LT250rs called www.quadracer.com. But, I think he sold his MINT lt250r and bought a Z400 So I don't know if it still exsists.
    Mar 2005
    overton, PA
    5,257
    ok my experiances are this, tecate wa sfastest, compared with a piped and ported trx250r, my tecate is pretty much all done, kinda remind sme of a blaster with an insane kx250 motor in it, i havent lost many races with my old t-4, but the oen i am buildign now is nice, all powdercoated, needs rear shock rebuilt, and blue side pannels, and a pvl ignition to make it rev alot better will sell for 2,000 or make an offer, verry nice quad, just needs 600bux to finish it. and as rar as havign the cylender welded and re nicasilled, it cosat me about 200 bux to have this done to std bore. but i am in the process fo building a tecate bottom end with the modern 97 kx250 cylender, makeing awesome power, and i ahve built one with a kx500 topend and a stroker crank, 466 stroker big bore motor. here is the link to a bunch of pics of mine. http://www.bikepics.com/kawasaki/kfx250/88/pics.asp
    Belsano, PA
    1,387
    I own a T4, and have friends with the other Brands....I like the Kawi for a few reasons...The #1 reason....It is unique. You don't see these things all that often and when you do, it is always the center of attention (for a little while anyway) A couple other reasons, it RIPS. They have a really nice power delivery. Smooth. They make really good woods bikes. Not real peaky (With specific portwork you can make it anyway you want, like any other 2 stroke)
    There are some drawbacks, as with most older bikes. If you plan on Racing your T4, I would not do it. Any serious racing will beat the crap outta a quad, and though many parts are still available, it will surely eat up lots of $$$$ buying them. If you want a fun trail machine and occasionally take it to the track, then sure, buy it. But, if you plan on getting involved in serious weekly racing, go with a Honda 250R. You can find them everywhere and the parts are plenty and not that high priced. (Not to mention, who cares about beating the snot outta a run of the mill Honda 250R :-) )
    As performance goes, it is irrelevant to compare Stock to Stock. You will not keep you machine stock, and neither will MOST of the people out riding these old 2 strokes. True it was faster than the other 2, but that is ONLY the 1988 T4. The 88s had a bit different tuning. The Carb was upgraded as well. (34 Mikuni to a 36 Keihin) The 88 also had a better front end. The ORIGINAL Long Travel Suspension (Gullwing copied & perfected by RollDesign)
    Like somebody else stated...go over to www.kawieriders.com and check out all the info for yourself. You will be suprised to find alot of people STILL ride these Green Mahines. Good luck
    Click the link below or in my Sig to see mine.
    http://users.adelphia.net/~cinnamonlou/pics/page8/
    Sep 2005
    Massachusetts
    1,272
    That sure is a sweet Tecate SpeedBump
    arizona
    550
    speedbump that thing is awesome!
    your right about racing though, i dont think im going to be a racer but ive never had a track worthy bike, if i get it il take it once in a while. not to many tracks that i know of where i live.
    i do alot of woods riding though, and the r is a pain in the arse in cold... btw speedbump, in those pics theres one of you dragging a banshee w a wheelie bar and some other stuff. howd you do?
    the ultimate deciding factor is money, or in my case, the lack of it , soon as i turn 16 im gettin a job though, so i should be able to afford it by x-mas.
