Results 1 to 13 of 13
Thread: 200X front end on 85R... Will it work?
    Mar 2004
    North Central Ohio!!
    2,712
    I was thinking that a 200X front end would be real good on an R set up for flat track. Shorter forks to start with and then slid up in the triples a little would get that front end right down on the tire. Also was wondering if a 200X rear shock would fit. That would certainly slam that back end down.
    Anyone know if it will fit?
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I kinda had this idea for my 500R to start with to keep the costs down and keep the front end low. I'm pretty sure you could if you changed the stem out. Probably also have to weld in some new frame stops. Not a major task.
    Newfoundland
    5,280
    Yupp, I remember seeing a 200X on here with `85 R forks. 500cc motor in the same plans as the 200X forks?
    Aug 2004
    Ab Canada
    4,368
    Where did i read on here somwehere that they used 350x front ends for flat track on R's
    1985 Tri-Z-
    Sep 2005
    canoga park
    121
    I always thought the 85r front end was better for a flat track. whats wrong with 85r ?
    mad_max is offline Just Too Addicted Arm chair racerJust too addicted
    Kansas
    462
    Quote Originally Posted by My trike Sucks
    Mike Coe stated that on his ATC 4 ME thread.
    Jan 2005
    Great Bend
    704
    Quote Originally Posted by trikes=fun
    there is really nothing wrong with the 85R. they are trailing axle fork design as the 350X's were leading axle fork design. the leading axle puts the front wheel out a little further and when combine with a shortend ride height in the rear it rakes the front of the bike out allowing it to set a lot easier in the turns and not be real twitchy. it also helps on the straight aways for high speed stability.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Old 179's Avatar
    Old 179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Southwest Indiana
    300
    Adjustable strut (shock arm) was used to lower rear end back in the days. I still have mine!
    Dec 2002
    749
    I believe the 250r stem is actually smaller than the 200x stem. I know when Kevin and I put a 250r front end on his 200x we had to bore out the 250r tripples a bit. So youd have to intall a shim in the 200x tripples to put the 250r stem in.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    CUYAHOGA FALLS, OHIO
    1,242
    Word
    derrick the forks are different diameters. mabey if you swapped the tripples also it might work. as for the rear shock it could work but would require some mods to the the lower mount. 1)drilling the hole for the larger bolt. 2) filing the sides flat to fit between the strut fork. the bottom fingers on the x are kinda half mooned. where the rs are flat fingerd. this will shorten it by about 2 inches. i know all this because ive had serious shock issues with my 84r. and ive experimented with 86r/84r/200x rear shock. still cant find a rear good shock. wtf!!! . anyone want to buy it no seriously
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    1,242
    oh yeah
    i have the 200x shock still if you want it. its almost done and ready to be mounted. just alittle more filing on the sides to make it fit.. let me know i will send it home with brandon.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    Mar 2004
    2,712
    Well, from what i'm reading I might just as well use the Tri-Z for flat track duty. Since it has alot more rake from the factory it should work better for that type of racing. Now if I can just find some shorter forks for it, i'll be in business. Also some extra large radiator scoops to keep it cool!
    Howdy's Avatar
    Celina, Ohio
    10,079
    I'm wondering if a front end off a machine like a KLT160-185 would work here. You wouldn't have quite the suspension, but you would have some and it would set your front end down.
    Howdy
