Thread: 250sx Brakes?
    Feb 2003
    11
    250sx Brakes?
    Did any of the 250sx models come with Disk brakes.
    I have an '86 and would like to change it over if it's do able.
    any input good or bad will be helpfull.
    Thanks
    Aug 2002
    691
    http://www.3wheelerworldforums.com/viewtopic.php?t=4702&postdays=0&postorder=asc&high light=250sx&start=20
    als250 did it, bolted a 200x front end to his, I've seen plenty of others done this way too, good luck!
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    Roanoke, VA
    4,038
    Nope. They never came w/ disk brakes. They were built for reliability. Im not sayin disks are not reliable, just not as reliable as drums. If you want more braking performance, bolt on the frontend of a 350x.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Rittman, Ohio
    6,276
    Arent those hydraulic drum brakes like the TRX? If they are, youre not going to get any improvment from a hydraulic disk other than you wont have to do the manual brake adjustments all the time. If they are mechanical drum, it would be a worthwhile venture.
    Feb 2003
    11
    250sx brakes?
    Thanks for all of your Ideals, I'll lookin to the front Fork swap.
    I didn't know that the drum brakes were any better then disks.
    Always thought disks were more drpendable.
    Thanks
