Thread: Air cooled 250r dimensions
    springville, PA
    6,185
    Ok 2 questions. First, what year has a smaller engine and what are its dimensions(LxWxH)? I'm thinking about putting one in my 200x and would like to know just how much modding I need to do to make it fit.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Mar 2005
    overton, PA
    5,257
    you would be better off with a xr250 or some sort of other 4 stroke in the 200x chasis, basicaly any of the small honda vertical engines will fit, some with a little mods and others will bolt directly in. just have to use your imagination.
    Jun 2003
    South of Rochester, NY
    3,470
    Ummm... aircooled R motors have the chain on the right side.... unlike a 200X with the chain on the left side. Not sure if you can "flip" the axle or swinger 180º or not.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by 250sxwheeliepop
    The 81-84 air cooled R engines have the same dimensions, the only real difference is the color and the length of the shifter shaft.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2004
    North Central Ohio!!
    2,712
    How about a CR125 engine. I'm dieing to see someone do it!
    Attached Thumbnails Attached Thumbnails 2 Stroke 200X.jpg   2 Stroke 200x 2.jpg
    springville, PA
    6,185
    Quote Originally Posted by 350x'inNY
    Bruce
    I see. I was thinking the 81 and 82 R's were right side and in 83 on they switched sides.
    I was thinking that an air cooled would be easier since I wouldnt have to reroute the radiator lines, so If I can just flip the axel and find a cheap engine I'll do an air cooled.
    Nate
    R.I.P HRR
