Results 1 to 8 of 8
Thread: 450cc in 200x
    Mar 2004
    Fond du lac,WI
    658
    450cc in 200x
    i have a 450cc engine in my garage. I think it would be kicka$$ in my 200x.
    what mods would i have to do.
    thanks
    springville, PA
    6,185
    Uhhh cutting and extending the frame for one.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Mar 2005
    overton, PA
    5,257
    depends what kind of 450 motor it is? i tried to get a cb350 honda engine to fit in my 83200x and had to literaly cut the frame into 2 pieces and make it bolt to each sid eof the motor nfd have a removeable conecting piece top and both bottom frame rails. buit the project was a loss doe to lack of time and intrest.
    May 2005
    Southern NH
    1,489
    yeah what is this engine????? after that like they said, cut the frame and it may be trickey to get the plasticts to fit after that......it's not like you just drop an engine in, kick it over and go you know......
    Jan 2005
    Spruce Head Island, Maine
    893
    might be easier to find a two stroke motor thats similar in dimensions to the 200x motor if you are looking for more power/speed.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Mar 2004
    Fond du lac,WI
    658
    its a 1982 honda motorcycle engine. 4 stroke and eletric start and 2 cylinder.
    Jan 2005
    893
    2 cylinder will make it harder to fit for one, and the height of the motor will make it difficult to fit. exhaust routing will be fun, youd have to go 2 into 1 exhaust, if the chain drive is on the wrong side you will have some more fun there, and as stated above, getting the tank and plastics to fit right if you do have to modify the frame.
    Past Rides:
    Nov 2002
    Kirkville, NY
    3,831
    Too much work to make a machine that is a lot heavier. I'm sure you could make it work but making it work well would be a different story.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
