Results 1 to 15 of 25
Thread: Very Bad Problem! HELP!
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    Unhappy Very Bad Problem! HELP!
    Hi dudes i have a 83 ytm200 that me and my dad have been working on for about a year. Today we took the carb and the 2 screws off to clean the carb. Then the worst thing happened possible!! My dad doesnt want to take the engine apart he says thats worst case sonario. But 1 screw fell in the hole that you mount the black rubber tube to the engine . We cant find the screw. Also are elctirc start option is dust to dust. ITs only pull start know but at the moment its no start because the screw jammed the pull rope!!! Anyone got any ideas to get it out??? PLease help anyone Thanks Joe
    Sep 2005
    Northwest Ohio(Forest)
    974
    just take off your pull starter
    '86 200x
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    can the screw go allthe way into the pull starter? Joe
    Jun 2003
    South of Rochester, NY
    3,471
    Hmmm.... I'd think your screw would have fallen into the cylinder. Do you have one of those magnetic fetcher tools? You can put that in where the screw went in, or take out the spark plug and go in from there. Basically an old radio antenna with a magnet on the end. It wouldn't get into the recoil starter.... if it fell in where the carb bolts to the cylinder.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Sep 2005
    974
    ohh i just realized what you said.
    do what he said and if what he said dont work then tip up the engine and wush it around and try his idea again
    '86 200x
    Brandon, Manitoba
    2,209
    If you cant get it out with a magnet, you'll have to pull the head off. I think a magent should get it, it wouldnt have got by the valves.
    hey, magnet through the spark plug hole.
    one cylinder is not enough!!
    Brandon, Manitoba
    2,209
    It wouldnt have got by the valve i wouldnt think, so it wont be in the cylinder. You would have to get it through the intake side of the head with the magnet.
    Dont turn the bike over at all, you might get it lodged in between the valve or something.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by YTM200BOY
    Did you try starting the motor after the screw fell into the Black tube ( intake manifold? )? If you did try starting it, did the motor turn over some and then stop suddenly?
    If so, it is possible that the screw fell into the intake manifold and down into the valve where it possibly got wedged holding the valve open. If the vavle is held open the piston will hit the valve and stop the motor from turning over. If this is the case, it's possible the vavle might have gotten bent when / if the piston hit it. I hope this isn't the problem, but I have seen it happen.
    Another possibility is the screw fell in through the vavle into to cylinder. I might also add that it is possible the valve was open in the first place and it fell into the cylinder.
    How to get it out: Remove the pull starter and rotate the engine backwards a little. Take the spark plug out and then using a fishing magnet ( like 350x'inNY described ) try fishing for the screw via the spark plug hole ( like 4cylinders stated ). If you can't find it then try fishing it out via the intake manifold ( Black tube ). More often then not I have found you can get them out via the plug hole though ( if it's in the cylinder ).
    I hope this helps.
    Howdy
    Jul 2004
    Mud hill. close to water !
    3,658
    Everything that Howdy said, and if all that fails.. consider the valve covers, might be able to find that in there..
    Good luck !
    Currently :
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    OMG IM SO PISSED! I hate this stuation!
    Oct 2005
    Pennsylvania
    863
    Worst case scenario , Bent valve - Couldnt he just change the reed block and be done with it?
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Oct 2005
    Pennsylvania
    863
    Oops sorry -200 is a four stroke aint it? My bad.
    Nov 2004
    Fort Kent, Maine
    2,132
    Quote Originally Posted by Unclediezel
    .................. hahahahaha
    YTM200BOY, did you try anything yet?
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Oct 2005
    Pennsylvania
    863
    Ok-ok-ok Im trying ---lolol
