Results 1 to 14 of 14
Thread: Alright what kind of carb is this?
    May 2003
    Shediac, New Brunswick
    1,126
    I just won this and Don't really know what it is... says it bolts on to a 200x intake, and it deffently looks oversized..
    Anyone?
    '84 Honda 200x
    slow restro
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    Looks like it says Mikuni on it beside the choke plunger, so its not off a Honda. Clean it up and see if you can get any ID off it.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Feb 2003
    California
    623
    They used to make an adapter for mikuni carburetors to bolt them to a 200x, for people that wanted a bigger carb for it.
    Oct 2005
    Pennsylvania
    863
    Thats definitely Mikuni- There were two mounting option "SPIGOT " or Flange. Thats a flange mount . Measure across The inlet side in MM to find a Group model
    And yes there was an adapter to mate those to hondas - but probably long since discontinued
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Oct 2005
    Pennsylvania
    863
    Is the throttle valve still in there? A machine shop guy could probably make you a plate on his lunch hour for a few bucks. Then all that would be left is cabling. Might be fun?
    May 2003
    1,126
    What do I need an adaptor plate for?.. I asked him if it would bolt to a 200x intake and he said yes?....
    Does this seem like it will be a good carb?..
    Also when people say the carb is a 22mm 24mm 26mm etc.. on what side are they measuring?
    '84 Honda 200x
    slow restro
    Oct 2005
    Pennsylvania
    863
    On the inlet side - All the way into the center
    where the air actually passes thru is the diameter you want to measure
    As far as a good carb-Try it out and see, maybe too big, maybe not-maybe jetting will bring it close to what you want, You wont know till ya try it. as far as the adapter---You have the carb and you have the bike in front of you--If it fits --Kudos
    If not, make it fit-(Adapter)
    May 2003
    1,126
    yeha I dont have the carb yet, it was an ebay buy. It diffently looks bigger than the 24mm stock carb.. hopefully it fits with-in the tight frame.
    '84 Honda 200x
    slow restro
    Oct 2005
    Pennsylvania
    863
    OK didnt know ya didnt have it yet. Its rare to find a honda Mikuni Combo. Bigger carb should help with Higher compression
    May 2003
    1,126
    Alright I finally got this carb. I measured the carb and i am reading 28.5-29mm .. but thats not in the middle.. just on the outer edge.. I only have a ruler.
    I dont see any numbers or anything on the carb, anyone have an idea of where they would be if they were on it? Also the floats are weird.. They are seperate and just seem to float around seperate from the needle valve.. not like the other atc carb's i've been into.
    '84 Honda 200x
    slow restro
    Richland WA
    808
    Look on Sudco.com, they might have a diagram. Float sounds broken, the needle should be linked to it with a wire clip. (?)
    Newfoundland
    5,280
    That is a VM series Mikuni. When you say the floats come away from the needle valve do you mean they stay in the float bowl? If so thats normal, my 34mm Mikuni VM is the same way. Simple carbs to work on too. Does it fit?
    May 2003
    1,126
    No I dont think the float is broken. It's just that the floats are seperate. It looks like it would work.
    Yes the carb will bolt right to a 200x intake, I don't know if it will fit in the frame or not though.
    Should I expect any gains from this? Is it worth the hassle? The slide is bigger, and the "in" side of the carb measures 40mm (where the filter bolts to or wtv) and my other carb is 35mm there.
    '84 Honda 200x
    slow restro
    Newfoundland
    5,280
    Expect a little loss in bottom end and a gain in mid to topend power.
