Results 1 to 8 of 8
Thread: Hi-Performance Atc Frame Yamaha R5
    Baltimore, MD
    6,088
    A few quick pics of the Hi-Performance Atc aftermarket frame I found with the Yamaha r5 engine in it. The R5 is the 2-cylinder 2-stroke engine they made before the rd350. This engine has no reed cages and it is known as piston ported. This frame will also take an rd350 or rd400 or any of that family of engines. It had no rear wheels or tank or fenders when I picked it up for $200. The rear axle is hollow. The rear disc brake is actually a front disc for and rd350. I'm looking to get a running bike to transplant the engine and could possibly make this street legal with a titled bike.
    Attached Thumbnails Attached Thumbnails 52268C8A51-06C3-CBD4-54CB3A17FC0C6BC6.JPG   55268F44A2-EA5D-F58D-308339DA4D010E9E.JPG
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    man that engine would kill some people in drags/
    Mar 2005
    overton, PA
    5,257
    verry interesting trike, and no the r5 motor isnt the fastest motor of the twin 2 strokes, the r5 being piston port makes it load up alot easier, and takes forever to build decent rpms, but onc eit hits that magical powerband hold on!, i am going to be buildign a 200s with a suzuki ts600 twin 2 stroke sooner or later, so well se ehow it turns out.
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    triples look like Nicholsons...check my 110 project on the restoration page...that frame looks very similar to it..
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Nice snag.That motor is kick ass.
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    that looks pretty cool. is it just me or is that rear axle real skinny. It may be the picture but it doesn;t look to be super stable.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Baltimore, MD
    6,088
    The rear axle seems about the same width as a stock 185s axle. The wild part is the axle is hollow. A buddy of mine who's an engineer says a hollow pipe is stronger than the same size solid pipe. Something thas has to do with having 2 walls or 2 sides as opposed to 1 solid piece. There is a sticker on the front triple trees that says "High Performance ATC" and has their address and telephone number. The company might have sold Nicholson frames, I don't know. I have seen their ads in several old 3wheeling magazines, but they didn't mention Nicholson frames. The r5 engine that is on the bike seems to have decent compression and is not locked up, as I put some oil down the spark plug holes and turned it over with the kicker. The electrics are pretty butchered up and look to be a nightmare to fix. I would like to find a complete running rd350 to put in the frame and hopefully find some DG Gold heads for it. I think the pipes I have are DG pipes, but they need cleaned up. It should be pretty wild when it is done. If anybody knows someone selling a running RD350 somewhere within 200 miles or so of Baltimore, MD., let me know 'cause I'm in the market for one.
    Baltimore, MD
    6,088
    I purchased a titled 1974 rd350 today that will be giving up its' engine to the aftermarket frame. Since it is a titled bike, I wonder what will it take to make it street legal. The donor bike runs and has all the turn signals, horn, lights etc. This could be the trike to go street legal. How crazy should I get? Just get it running oldschool, or try and make it street legal????
    Attached Thumbnails Attached Thumbnails 68F92A7C-D0E8-8017-673AA45212839BE2.jpg
