Results 1 to 15 of 16
Thread: Installing a tube into a tubeless tire, can it be done?
    Sep 2005
    Texas
    6
    Can you put a tube in a tubeless 25x12-9 three wheeler tire? Mine arent holding air very well, I want to know if i could just intall a tube in the tires, switch out the vavle stems and that would fix my air problem?
    Mar 2005
    Alberta
    503
    Quote Originally Posted by Anglin_Texas
    Sure can. Just make sure there are no rough spots on the rim or sharp objects inside the tire.
    The only 2 problems that you might have is that sometimes the valve stem placement on the tube isn't lined up with where the hole in the rim is & you have to roll the tube a bit to make it work, this puts some stress on the valve stem.
    Also, If you run too low of air pressure in the tube, the tire will rotate on the rim over time & rip the stem out of the tube. I've put tubes in leaky tires before & had them last for years though.
    A whole bunch of trikes.
    Jul 2004
    Mud hill. close to water !
    3,658
    Not good on 250 R's .. but on just about any other trike.. not a problem in most cases.
    Try to find tubes with metal valves if you can find them..
    The high powered trikes will spin the beads in most cases and it slices the tubes right off.
    Otherwise. good to go.
    Currently :
    Sep 2005
    Northwest Ohio(Forest)
    974
    i would try slime first if i was you
    '86 200x
    Richland WA
    808
    Ive always run tubes in tubless, even on a 250R on good ITP rims, that plus green slime good combo for hare scrambles.
    Watertown, New York 13601
    3,382
    Quote Originally Posted by cragster
    I would use that first too. I have spun the valve stems off tubes on a kawasaki 220 boyou before, and they have no power.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    leroy, new york
    1,025
    IS it a hole or is it a leaky rim. If it is the rim buy a can of hub and seal you tires. that **** is awsome.
    Oct 2005
    Pennsylvania
    863
    Tire slime works great and is alot cheaper than tubes -try it -the worst that will happen is wastin a few bucks- But Im sure you'll love it.
    Oct 2005
    Pennsylvania
    863
    Just a thought --Dont know if Slime will work inside tubes--But Keep any extra you have- And just for giggles pump it into your tubes- It never completely dries out -so youll be protected against punctures permanently.
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    I have to say my experience with slime is that it doesn't work at all. It couldn't even seal up pinholes regardless of how long I let it sit to dry without riding it but still making sure slime was at that spot to seal the hole. The stuff says it can seal 1/8 inch holes with the regular type and 1/4 inch holes with the heavy duty type, well I used the heavy duty type and it couldn't seal 1/64 inch holes. When I first got the stuff I put it in all three of my new tires thinking it would be great and it didn't do a thing, just kept spewing out. Fix-a-flat is amazingly better then slime, keep a can of that stuff with you and your good to go.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Jan 2005
    RI
    2,530
    only thing about fix a flat is that it hardens...and if you have an unsuspended trike, hard tires mean severe back pain
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jul 2004
    3,658
    Slime won't fix sidewall holes.. as it flings itself around the tire when it turns... what portion of the tire was the hole on ?
    Currently :
    Hampton, Virginia, C.S.A.
    2,664
    ive fix a bunch of 3wheeler tires as well as orther tires with fix a flat
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Sep 2005
    Massachusetts
    1,272
    My experience with fix-a-flat is great. About 2 years ago I popped my front tire on my XR. I wanted to go riding that day so I bought a can. I put it in and waited a little while. Then I went riding. Now 2 years later. It is still holding like the same day it was 2 years ago. I can't say the same for truck tires. Probably just too big. So, I guess fix a flat works great for small tubed tires like dirtbike tires. I'm not sure how it would hold up with a bigger trike tire.
    Aug 2005
    Lancaster, PA
    316
    The hole was not in the tire sidewall, I understand how it sits in the tire and that it doesn't even touch the sidewalls, but this hole was right in the center of a tread section, I could watch the slime flow out of it and just keep on leaking, it's really not good stuff. Fix-a-flat holds up great on trike tires and hardens like rubber, it won't make your tires stiffer at all in any way, it'll just make a rubber like membrane on the inside of the tire after a while that is very thin and you won't notice any difference in stiffness or tire mass/weight.
    Trikes
    Bikes
