Thread: 84 250r problems
    Oct 2005
    canada
    51
    84 250r problems
    my 250r is killing the plugs. and when i pull the plug out after it was running is it soked in gas plus the plug is black. when im riding the bike it seems like its bogging down or lagging. would this be a reed problem. Or if anyone has any info on this please respond. thanks chris
    Sep 2005
    Massachusetts
    1,272
    Sounds like a jetting problem to me. Your running too rich. Main jet is too big I think.
    Oct 2005
    canada
    51
    the main jet is a 142
    Poplar, WI
    531
    I am approx the same elevation and proble temp as you, and I am running a 125 main...I would drop a main jet for sure (more than likely a couple sizes), but dont do anything real drastic. I had the same problem as you with the gas and color, so I dropped 2 sizes.
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
    Poplar, WI
    531
    Oh, by the way...when you check your plug color do you kill the motor at higher RPM's or let it idle down like a 4 stroke and kill it?? If you shut her down at a higher RPM it will give you a bit more of a true reading, but you are too rich
    Oct 2005
    canada
    51
    yesa im going to buy a 138 and a 140 jet tomorrow and see how it will work. thanks for the help any more info would be great.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    I need a 86 250r Headlight lens!!!! Hook me up!!!!
    Westcoasters check out the Florence ride....
    http://www.3wheelerworldforums.com/s...ad.php?t=42267
