Results 1 to 8 of 8
Thread: Is this the clutch slipping??
    thebutelr's Avatar
    thebutelr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Golconda, Illinios
    160
    Angry Is this the clutch slipping??
    Hey guys, i just installed a 10.5:1 wiseco and a web cam in my 350x. I just finished putting this thing back in time and now when I take it out and ride it it wants to rev up really fast and stay in the same rpm through the gears. Kinda acts like the clutch isn't grabbing. Could that be what it is? Or maybe valves are way out of adjustment??? I'm really lost on this one so any help would be appreciated. Thanks a lot. Later.
    Oct 2005
    Pennsylvania
    863
    Ok- you must have the webcam wired wrong!!!!!
    But seriously- Increased compression = increased vacuum= Increased need for more fuel. I would aim at a jet change first.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    thebutelr's Avatar
    Jun 2004
    Golconda, Illinios
    160
    Lol. Do you really think it could be something as simple as a main jet???? I mean it really doesn't feel like a jetting problem. But thats just me.
    Oct 2005
    Pennsylvania
    863
    does your engine scream away if you run out of fuel? Kinda same situation. Main jet -or possibly pilot sucked up some junk. At worst -a vacuum leak- check around carb mounting area with some carb cleaner. if idle changes -you found your suspect.
    Phoenix, AZ.
    6,719
    Also check your exhaust headers. Make sure they haven't come loose. Had that happen twice on the 200x and it felt like a bad clutch both times.
    Oct 2005
    Pennsylvania
    863
    ooops--thanx dammit---forgot that one--Make sure your exhaust is tight -lol
    thebutelr's Avatar
    Jun 2004
    Golconda, Illinios
    160
    Thats good to hear its nothing seriously wrong (hopefully.....knock on wood lol). I'll check those things first thing tomarrow and tell you guys what the verdict is. Thanks a lot unclediezel and "dammit!". Later.
    thebutelr's Avatar
    Jun 2004
    Golconda, Illinios
    160
    Well I found the culprit.........an incorectly adjusted clutch cable....LOL!. Thanks guys for all ** help on this.....now off to get it jetted right . Well i'm out, later guys.
