Thread: which exhaust is better?
    Indiana
    115
    I am planning on buying a quiet exhaust soon for my 110. I can get a Cobra Quiet Series, or a DG RCM atv silencer, both for about the same price. Which one would you reccomend for me? I'd like to get the quietest one possible, because I will be using this 3 wheeler while hunting, and I don't want it to be too loud. Also, I believe when I put a new exhaust on, I will have to re-jet. Is this correct? The stock jet size is 85, how big would I need to go? Thanks.
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    i would say use a stock on if * have. stock are really quite kinda. but i would say out of those go with th dg rcm one. it looks smaller and not that loud compared to pictures of the cobra. plus cobra has shitty paint and melts off first time ran. I dont think * have to rejet.
    Brandon, Manitoba
    2,209
    You might have to rejet, check your plug.
    Stock jetting is known to be rich most of the time, so the new pipe could level it out. But always check, you dont want to melt your piston.
    Indiana
    115
    Quote Originally Posted by traxxasx
    The exhaust on the bike currently isn't stock. I have no clue what it is. It's pretty loud, and has several holes in it, so it needs replaced.
    Sep 2005
    wisconsin
    475
    both pipes are preety good, my friend has a cobra and his is really loud and one has a dg, both are really good pipes i would say the dg is quiter, and * will proablly want to step up to a little bigger jet, idk ask around for someone with the same trike
