Results 1 to 14 of 14
Thread: 350x backfire
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    Question 350x backfire
    Anybody with a 350x ever have popping (backfiring) after the engine has been revved high? When I let off of the throttle after ing it the engine backfires several times. The bike runs strong, but I was curious if this is a common trait.
    springville, PA
    6,185
    Its common on alot of ATVs, especially if you go down hill and let off on the throttle.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Oct 2005
    Pennsylvania
    863
    Believe it or not -Exhaust systems are not for noise control -power enhancement- Or just to look cool---Its a Flame arrestor for backfires (Spark Arrestor)
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Oct 2005
    Pennsylvania
    863
    If you ever watch drag racing on TV- The flames that come from the exhaust are completely normal
    Baltimore, MD
    6,088
    I know that if you have a leaky exhaust gasket or a lean fuel condition that it will cause the back to backfire when you rev the engine up and let off the throttle real quick. Often if you change to a different air filter or exhaust the engine will begin to backfire alot. It usually means you have to rejet your carb.
    Mar 2004
    Andale, KS
    114
    My 350X only does it when it is revved extremely high in a high gear. Other than that it runs smooth.
    Current Rides:
    1986 350X-My play bike!
    1985 250R-My dune baby!
    Past Rides:
    1983 250R
    Jan 2005
    Spruce Head Island, Maine
    893
    its excess gas igniting in the exhaust i believe
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    ovhonda1's Avatar
    Sep 2005
    Louisville, KY
    369
    thanks for the replies everybody.
    Richland WA
    808
    Yep, excess gas. It can be caused by too lean an idle mixture.
    Sep 2005
    wisconsin
    475
    yepp, my 200x also does it when i got her pinned in 5th and let off, it gives off a pop or 2
    breastman569 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    Tucson & Mesa, Arizona
    272
    anyone ever tell you that you timing is off just a little check it and bet it will solve everything. my 200X was doing the same thing and sure enough that was it. check that first.
    Sep 2005
    Massachusetts
    1,272
    Every 4 stroke I've ever owned (xl80s, xr100r, lt185) always backfired when using engine braking going down a hill.
    Tionesta, PA
    5,741
    My 350X did the same thing when I had the cobra muffler on it. After switching over to the 450R muffler it has stopped. Are you running stock exhaust / muffer, or aftermarket?
    Go up one size on your idle jet and it should quit. Your just lean a little.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
