Results 1 to 8 of 8
Thread: 200 Big red power specs?
    springville, PA
    6,185
    1984 200 Big red. Does anyone know the power (voltage, ohm, ect) specs? I have no power to the plug and I am trying to find the weak link. The fuse is fine so I guess its process of elimination now.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Apr 2002
    s.w. michigan
    6,498
    If I can find that manual ,,,
    Been looking for that clymers manual for a hour now ,,, !
    john
    springville, PA
    6,185
    lol, ChrisG found his so he sent me the specs for the voltage regulator and the coil. I dont think that meter you gave me goes to a small enough ohm reading because I checked the whole electrical system on ohms and it didnt move at all. I checked it on the battery and it worked fine.
    Nate
    R.I.P HRR
    springville, PA
    6,185
    ok I went out and measured one more time to make sure it wasn't a PEBKAC type of problem, and I'm still not getting any measurments on ohm for anything. But on volts it works flawlessly.
    Nate
    R.I.P HRR
    Apr 2002
    s.w. michigan
    6,498
    in the ohm setting
    Just to check your meter ,,, put the 2 ends together (set in ohms setting) and the needle should go to the far right (pegged).
    The good news ,,, I found my flip flops I have been looking for about a week now in a room upstairs that has or back up computer.
    Gonna double check all 12 rooms in this house plus basement + garage for that stupid manual ,,,, this is gonna drive me nuts.
    john
    Apr 2002
    s.w. michigan
    6,498
    got it narrowed down ,
    The manual HAS got to be in my other work truck. The last known thing about it was I copied copys from it to send to Gocartjon wanting some info from it. I reckon I will be going into the shop tomorrow to find out.
    john
    springville, PA
    6,185
    I got a different meter last night and I have some questions. on the coil I tested the primary and secondary winding values and for the secondary I got 3k ohms which is in the range, but for the primary I should get .2-.4k ohms and it just pegs out (like when you touch the two prongs together on the meter).
    Also on the CDI some of the male ends check out ok but others won't read anything, and some are supposed to read infinity.
    I'm thinking both of these parts are bad, but what do you guys think?
    Nate
    R.I.P HRR
    Aug 2004
    Ab Canada
    4,368
    your primary is shot if you get infinity on it.
    1985 Tri-Z-
