Is there a difference between the 85 and 86 250r motors? Did they change anything? Any info will help.
Thanks denn
Thanks denn
I know the carbs were changed.
Go to servicehonda.com, go to genuine parts finder and look at the differences between the two.
I believe the only difference is the weight of the flywheel & the color of the paint, 85 was black & 86 was grey.
every year had a different weight flywheel and difference cylinder head, don't know the reason for the change, the 88/89 flywheel is advanced 2 degrees. from is visual look the 85-87 heads have a smaller dome, 88 is alittle less and 89 is the least.
What are you looking to know exactly? Do you have a pile of parts you want to put together, or just swapping engines?
I'm building an 86 250R from nothing. I am going to need an engine. I was just wondering if an 86 engine was improved over an 85. I would like to try and keep the bike all 86 but if I can come across an 85 engine I could just change whatever the differences are between the 2 years. I really don't know much about the honda's. I have been strictly a TRI-Z guy for 15 years. I got one when I was 13 and never rode anything else.
Thanks Denn
Yeah, I've been there. 85-86 are essentially the same thing. Its when you hit '87 that you get into different gearing, long rod engines, clutch setups, blah blah blah. However, they'll all fit in your chassis.
Trikes don't kill people. I kill people. Now that is awesome!
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
i thought the ATC 250R was already a long rod?
Rest in peace Rex Carlson
I think it was in 87 that they went to the long rod crank. I'm currently building an 86 with a long rod crank. I will need a piston for a 87+ to compensate for the increased rod length. The long rod is 5mm longer so the piston pin is set 5mm higher in the piston.
You can acutally run a long rod with the 86 piston, you just have to get a 5mm spacer plate under the jug. I think spark plug to frame clearance is pretty tight if you do this on a 3-wheeler.Originally Posted by X2guy
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
82,79 XL500R
83 ALT50
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72 SL100
70,69 Z50
Its not too bad, I use spacer plate motors, don't even try it if you are gonna use a cool head though, or any aftermarket head. the spark plug is so hard to get to,
Blown, you're a cop?Originally Posted by Blown 331
85 ATC250R
someone told me that the early 85's were 5spd
Someone didn't know what they were talking about.Originally Posted by movistargixxer
