Is the 83'-86' R's front rim the same as the 83'-85' 200X's? Need to know cause you can buy a new ITP wheel that is a 10" instead of the stock 11" from Dennis Kirk.com please help would be great. This could open up tire choices big time...![]()
My Rides
225DR Yamaha(unknown year and rough)
So to be looking for a Tri-Z to rebuild
I believe a 83-84R front rim has the same bolt pattern as a 83-85 200X.Originally Posted by Nick_n_ii
A 85-86 350R rim has the same bolt pattern as a 350X.
Hope this helps.... I know for sure that the 200X rim will NOT fir on a 350X or a water cooled R hub. Worse comes to worse, use a 350X hub or a 250R hub on the 200X front axle/forks.
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
a 86/87 200x rim will fit a 350x, 85/86 250r and 85/86 250x. 83/84 250r are different, I'm not sure about 83-85 200x's, also 250r front rims will fit on a 86/87 tecate 3's.
I looked on dennis kirk's site and the only 10" rims are rear rims
In the catolog it lists a front.. rim 10x5 with a 2+3 offset and group #4110 steel wheel part# is 55-1053 $36.95 AMS rim bolt pattern 4 on 110 need to cross ref. stock bolt patterns and offsets...................see what you cccan come up with on this............
My Rides
I want a 350R lol
Where can i get one?
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
Why don't you add some info to the thread...Originally Posted by edog
If it's a 4 -110 pattern, they are talking about the rear rims. Either case, the front rim bolt pattern is NOT a 4-110.
Bruce
the catolog is hard to follow it is vary miss leading I'm going to try and call them and get a straight answer.........
My Rides
