Results 1 to 9 of 9
Thread: 84 tri-moto 200 chain drive score!!!!
    Upper Black Eddy , pa
    245
    Unhappy 84 tri-moto 200 chain drive score!!!!
    got a 200 for $50 bucks delivered off of a friend its not in bad shape . there is a broken chain adjuster bolt in the carrier & the pullstart assembly was full of water & mud . hasnt been run in 2 years but i sprayed down the cylinder & spun it over with a ratchet & it felt pretty smooth & made compression . i geuss ill take the tire & hub off & try to drill & tap out thre broken bolt out of the alum. carrier hopefully that isnt gonna suck but it was def. worth a FIN
    1973 atc90k1
    cobra exhaust,1978 thumb throttle ,& pegs
    '80 honda 110
    '84 yamaha 200 x2
    '85 yamaha 225 dx 4sale
    '85 tecate 3 basketcase
    '85 honda 200x
    '02 blaster race quad getting full rebuild
    '88 suzuki quadzilla sold miss it
    '00 honda XR650R supermoto
    245
    any body know what the model designation is exactly for this
    1973 atc90k1
    '80 honda 110
    '84 yamaha 200 x2
    '85 honda 200x
    Nov 2002
    Kirkville, NY
    3,831
    Sounds good, almost any nearly complete machine is worth $50! It is a 83-85 YTM 200 (plain 200, no letter designation except for the year).
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Oct 2005
    Pennsylvania
    863
    YTM200L- Nice Score!!!
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by Unclediezel
    It would only be an "L" if it is a 1984. It would be normally referred to as a YTM200, if it is an '83 it would technically be a 200K, '84 = 200L, '85 = 200N. The K, L, or N just marks it as a specific year. For example the 225DX in his signature could also be called a 225DXN because it is a '85. The only time you need to use the extra letter is when ordering parts because there are slight differences between years.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Oct 2005
    Pennsylvania
    863
    Yes - The letter is only year code- YTM200
    Nov 2005
    Wisconsin
    4
    Quote Originally Posted by thefox
    I am new to this forum and hope you could help me out with something. I have A Yamaha 225 DR . But I dont know what year it is. Could someone tell me how I could figure it out? I think its either an 85 or 86. Thanks in advance.
    Oct 2005
    Vicksburg, MI
    73
    My brother just found one today for $50. said the rear axle bearings are bad or something and needed the slide for the carb. Didnt get it thought? Also found a '84 250r for $50. Needs top end. Should get but it is real rough.
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by hunter1630
    Look on the engine case under the carb. (from the right side of the trike) there are #'s there. If they start with 1EV then it is an '85 if they start with 1NV then it is an '86. Hope this helps!
    Oh yeah, Welcome to 3 Wheeler World!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
