I want to get an aftermarket seat cover for my tri z but haven't found much for it. Would a seat cover off any of the other yami quads fit over the stock tri z foam correctly?
http://photos.yahoo.com/dynofox250 (TF 03 pic's)
Trikes: Restored '86 ATC 250r, original and mint '83 185s
Quad: '86 TRX 250r
Sled: Rev X 800ho mod
Bike: '00 ZRX 1100
TF '03 and '05 Survivor
Did you check with atvseatcovers.com ?? I dunno if they will have one in stock but the one I bought for my R was only 20.00 and it looks really nice, I'm sure he will make you one if you can wait--good luck
1985 YAMI TRI-Z RZ350 POWERED
1986 250R STOCK WITH FMF & K&N
1986 TRX70 mini golf cart
TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
I was looking at a ceet seat cover and all they stock is the standard black cover. I called them today and they told me if I wanted a red one with yamaha on the sides it will be an extra $25. I will most likely plan on doing this.
Quad: '86 TRX 250r
Bike: '00 ZRX 1100
As far as I understand a blaster seat cover will fit. It might be a little long on the bottom where it curves up but it might work. I am not positive on this, but that is what I was told. Let us know when you find out.
1985 tri-z needs a little work
2003 400ex
1999 yamaha warrior, for sale
2006 yamaha raptor 700
1986 atc 500r wrecked & mostly parted out
1984 yamaha pw50
I second Rod's post. I believe Tri-Z Jim used blaster seat covers for those awesome Z's of his.
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
I have seen tri-Z's with blaster seat covers on them, and what Jeb and rod have not mentioned, is that the seat cover has to be trimmed around the edges because a blasters seat foam is taller then a tri-z's. But when done correctly it looks real sharp.
I have noticed Warrior seats look pretty similar
