How can I do this? Sandpaper?
I tried paint thinner with no luck. The reason I want this is because I love the look of straight black not black with the orange razr embedded in the tire.
Thanks
Thanks
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
Is this stuff anything like the "BLUE" on new car tires- I work for bridgestone and they told us to clean it off with Glass cleaner--and it worked Great.
Buy American! Unless your only option is a HARLEY.
A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
No, its not like that blue stuff on the tires. I know what your talking about. I would try to peel it off very carefully with a razer blade
possible something like acetone? Or how about a wire brush on a dremel? I want to do the same thing...
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
Is this actually a decal-----carb cleaner and heat gun ---(ON LOW OF COURSE)
Is the emblem on both sides of the tire?? If not, just flip the tires on the rims.
I have seen the tires but never looked closely at them, Is the RAZR name raised on the tire? If so maby use some 200grit sand paper with a sanding block and lightly remove the raised letters. If they arnt raised then you could try to black them out with shoe pollish
there not a sticker, its painted on. or somehow they inbedded color into the tire. try some fine sandpaper. but after awhile of use they'll just wear off anyway.
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
Thanks guys! Ill try some sand paper and see what happens![]()
#NOLINK
#SUSPENDTHIS
Tape the contour of it with masking tape.. and spray paint it black..
If you grind it off . you will have a nasty looking scuff mark on the sidewall... yuck.
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
I wouldnt reccomend using any acetone, carb/brake cleaner/ or any other corrosive liquid, it will eat away at your side wall, and cause premature ware on the sidewall. I think your best bet is some super fine sand paper or some flat black paint.
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
Trade tires with someone...
[20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
keep em dirty and you'll never know![]()
I got those dirt devils turned around so you cant see them![]()
